Frozen Navigation Screen Fix DIY
#451
Thanks for the great write-up. I actually had mine replaced under warranty about a year ago but my buddies has been out for about a year so this will be very helpful to him. Mine stopped working suddenly when i disconnected and then reconnected my battery one time when cleaning my MAF.
#454
It seems as if there are 2 seperate issues people are having. The first is the"Frozen" issue that is resolved by the DIY digitizer fix, new digitizer, or replace the whole screen.
The second issue is the one no one can seem to answer & that is the Black/blank screen & none of the buttons on side or below work, while the clock, radio(without display), hasards & security work.
In my research if seems as the blank/black screen issue is caused by the fan on the main PCB going out & the board frys. This is the board for $299. https://www.aliexpress.com/store/pro...313001011.html this one is out of the country.
This one is in the country but out of stock. http://opuradio.com/products-detail.php?ProId=771
I see several people posting about the blank/black screen but no one ever talks about how to fix it. Has anyone changed this board? if not how is everyone fixing the blank screen issue?
#455
This thread and been INVALUABLE. Thank you to everyone who has contributed to a solution!
I did attempt the conductive pen method with the held of my friend, who also did this for his 07 IS350 before shortly trading in his vehicle. Unfortunately this did not work out with the same success for myself so I went ahead and swapped out the digitizer.
SHOUTOUT to Mr2KiEu for helping a fellow forum member out! I think we were done in an hour since I had previously removed the ML Navigation Unit, which made this process go a lot more smoothly.
#456
#457
I tried the circuit writer pen fix but it also did not work correctly for me. So I ordered a replacement digitizer from a forum member here and I installed it last night. Everything works perfectly as it should. My only issue is that I should've read all the pages here first and see that the glass is held on with double sided tape. I found a video on YouTube where the person fixing it used a heat lamp on it to soften it to remove. I used a blow dryer and credit card lol.
#460
Heat Gun?
Question around using the heat gun. How long did it take to loosen up? Did you just go in a circular motion around the edges of the screen? Any suggestions would be appreciated, I just don't want to damage the LCD with the to much heat. Thanks again.
Thanks to all the info available I replaced the digitizer on my LCD yesterday. I tried the silver pen fix but still had 1/4 of the screen unresponsive. I ordered the digitizer linked below and it worked great, also so far have not noticed any rainbow affect some mention with low end digitizers. Used a heat gun around the edges of the old digitizer, then separated from LCD using a razor blade. There was plenty of glue left over on all but one edge, I used double sided scotch tape (thin clear stuff) on that edge and everything went back together easily! Highly recommend this over the silver pen, for only an additional $25 over the pen fix get a new digitizer. I received the item within 4 days of ordering...not bad.
http://www.ebay.com/itm/321267077853
#461
Why don't you just take the LCD out of the frame while playing with heat gun? It's really easy,
1. Straight up 4 metal tabs around the screen.
2. Using something small to pushing up the clip and getting the screen off.
You will see those thing on the back on the screen
#462
Here is step by step how to superate the LCD and touch panel
Throw the screen look on the back. Notice the metal tabs on 4 conners
Thepointing out the tab I'm talking about
Straightening them up
My fingers pointed out the plastic tabs on the lcd
Using small flat head screw driver insert to the slot and pray it up. The tab will be real ease itsfelt
Doing same thing for the other 3 slots
Make sure start from the touchscreen connector first
Just just pray it just a little to release the tab only
The LCD now could be off the frame and superate from the touch panel. Just remember, lift the LCD from the side of touchscreen connector
They are apart
When you putting them back on, putting the LCD connector side in first. Pay attention on the small guide pin of the LCD
Hope it helps you guy
They are apart
#464
A hair dryer gets hot enough, the heat gun might be a bit overkill. Just keep it moving so as to not melt anything or let anything get too hot.
#465
Not really a glue or tape, these usually use an adhesive transfer tape of some sort. Its basically like that gunky glue used for packaging that can peel off in a single strip.
