Frozen Navigation Screen Fix DIY
#556
Dead Touchscreen, A/C stuck 'on'
Great thread, all!
I've got a '97 SC300 manual, a'04 LS430 and am looking at an '06 IS 350 for my 19 yr old freshman starting college 5 hours away.
This IS350 has chunked wheels (not a big deal), the typical 'soft dash in the summer' issue, AND a non-working touchscreen.
That's where the twist comes, for which I need input. The Seller says:
"... no blue tooth in the car has a aux cord. the screen went black though. so you cant change the climate control. the ac is stuck on..."
1. Is there a connection between the screen going out and the inability to shut off the A/C?
2. Is there no Bluetooth in an '06 IS.50 with these options: Premium Package (perforated leather, heated/cooled seats, wood trim), HID AFS, 18" Wheels, Preferred Accessory Package (wheel locks, cargo net, trunk mat), and Lexus Premium Audio System?
I appreciate all the help you all can provide.
Thanks,
Bob
Atlanta
Thanks,
Bob
Atlanta
#557
Unfortunately,the 2006 Lexus IS 350 only has Bluetooth available per handsfree phone, and need use of a bluetooth adapter for the music.similar to the following. Also, search Cruthfield / Amazon as well;
The BEST CHEAP Bluetooth Adapter for the 2nd Gen Lexus IS!
GROM Vline Infotainment System
https://gromaudio.com/vline/
GROM-BT3 Bluetooth car kit (TOYLB3)
https://gromaudio.com/store/bt3_adap...interface.html
PAC SNI-1/3.5 3.5-mm Ground Loop Noise Isolator;
Kinivo BTC450 Bluetooth Car Kit
https://www.kinivo.com/products/kini...ux-input-apt-x
2006 Lexus IS 350 Owners Manual;
https://www.manualslib.com/manual/13...age=203#manual
gromaudio (07-26-23)
#558
Great thread, all!
Thanks,
Bob
Atlanta
Thanks,
Bob
Atlanta
#559
Sounds like similar issue discussed here;
AC not working on 07’ IS350
https://www.clublexus.com/forums/is-...07i-is350.html
#560
Black navi screen is due to a power supply module within your Navi system.
Use the voice commands to change your climate in the meantime until you get the Navi fixed.
Climate Commands
Command Alternate Commands with same function
Automatic Air Conditioning Automatic Air Conditioning On, Automatic Air Conditioning Off
Raise Temperature Warmer
Lower Temperature Cooler
65 Degrees Temperature 65 Degrees
82 Degrees Temperature 82 Degrees
83 Degrees Temperature 83 Degrees
84 Degrees Temperature 84 Degrees
85 Degrees Temperature 85 Degrees
Climate Commands
istarzan (07-26-23)
#561
More than touchscreen not working
Very nice write up!
I may have missed my issue in this thread (boy is it long!), so please excuse the following if i did.
I recently bought an '07 IS350.
The Seller advised that the touch function was out and that she had a new part from Amazon in the glove box and included with purchase.
I bought the car and when I received it, she was correct.
However, within a 3 weeks, the screen went black (not illuminated). At first intermittently, now constantly.
I learned quickly to leave the A/C on AUTO (it's still in the 90's in Atlanta) lest I lose the ability to turn it on. However, it's now ALWAYS on.
The 'hard' switches immediately below the screen but above the strip of climate controls, clock, temperature adjustments and emergency flasher are no longer illuminated and do not work.
I found a local fellow who repairs screens, ECU's, instrument clusters and door actuators. He advised that my issue is past the screen &/or digitizer but is a a circuit board issue.
Is he correct?
Is $395 to remove, repair and install at my home a fair price?
I appreciate your comments.
Thanks!
Is he correct?
Thanks!
#562
Very nice write up!
Is he correct?
Thanks!
Is he correct?
Thanks!
#563
I belive it may not be the digitizer, but possibly the climate control module itself.
A member has experienced very similar issue discussed here;
AC not working on 07’ IS350: https://www.clublexus.com/forums/is-...07i-is350.html
#564
#565
#566
Fixed!
I had found a local fellow who repairs screens, ECU's, instrument clusters and door actuators.
He came to the house and removed my unit, went to his shop and repaired the circuit board and other issues and returned Saturday even ing to install the repaired unit.
All features are working correctly!
Cost: $395, Remove/Repair/Re-install.
Pics attached.
If you are local and need this contact, PM me, please.
Pics attached.
istarzan (09-25-23)
#567
My AUTO climate control acting weird
When started, the orange front demister light flashes for 20 seconds, then green light comes on for outside air. No fan, no AC. Temp setting, 25degC. If I then increase fan speed to one notch, AC then lights up. I then need to adjust temp down. Basically it's not saving past setting in memory. This happened after I blew a ACC fuse on passenger side working on the amplifier this have happened earlier so I just replaced the fuse. But after that the ACC system started acting up and I have no heat. I tired disconnecting the battery after I turn on the car it make very lound noises I think it's the servo motors trying to do there thing but something is not right inside the dash. All so the cabin air filter door is broken but it's like that from the starting.
