Frozen Navigation Screen Fix DIY
#91
I usually don't make many posts, but I felt that this instance would be appropriate.
First, after reading this whole thread, the directions were pretty much spot on. My navigation went out last week, and I have been researching my options on what to do. I scheduled an appointment to get a new screen, but figured that since I would be paying $2400 for a new screen (plus installation) I might as well give this fix a shot. I just finished about 10 minutes ago and everything works! Thanks to everyone who has contributed to this thread, you just saved me a ton of money. The total cost was $20 for the circuit writer. Great job guys!
I would like to clarify two thing to those who are going to try this fix:
- Once you meter the connections and find the faulty strip, YOU NEED TO ETCH THE GLASS till you get to the copper. I used a Dremel pointed stone bit to etch the glass till I was able to make a connection (I tested again with the meter). Since I did this by myself, I scraped all 4 connectors on the ribbon (Screen side) so that I can test while touching the screen. Strip 1 (from the front) was my culprit. I then used the circuit writer to make the connection.
- Take your time while etching the glass. It would have been great if I had a magnifying glass built into my workbench, luckily my eyes are still good. just make short strokes and focus only on the glass.
Again, thanks everyone for putting in, it was everyone's input that helped me. I am just hoping that my $.02 helps someone that is unsure about that part.
#93
I attempted to do this fix and for the finally finished this morning. The result was the touch did work but still not as responsive I had to press real hard and only the bottom half of screen was responsive but the top wasn't. Any ideas before I purchase a new screen? And where can I properly buy a screen? I know some said eBay how long did it take to get?
#94
#95
I got pretty deep with my etch, chipped the screen and everything I also got readings from all four traces but still gives problems with the response
#97
I too just attempted to fix my screen this Memorial weekend... and I'm happy I did. For some reason, I couldn't get a good reading on the meter, so I just decided to do all four. I guess i was lucky, I didn't have to etch the glass like everyone was saying to do. What I did was just get at the ribbon that was just under the glass and it worked. Also I had to do it a couple of times. Because after the first try, I notice the touch was off, for instance I was touch the screen at dead center, but it would trigger about half an inch above that. After the 3rd time, it was good as new.
Also i noticed when I plugged everything in and started the car, the navi would re-boot and after the first attempt, there would be vertical lines going across the screen, and at first they had yellow line going down, and then on the final try, I notice all the vertical line were a solid light blue color. Did anyone notice that, I think that was kinda like proof the connection was good.
#98
#102
I keep my eye on this thread. IF you two have questions post em up as you're doing the project. I'll try my best to reply in a timely manner.
Keep in mind your AC WILL still work even with the nav unit out. Whatever temp and settings you had on the ac prior to removing the nav panel they will remain the same. So if you need to drive around while waiting you can.
