Lexus dealership screwed up my is350!!!
A few days before Christmas I took my 2007 IS 350 (56400 K miles) in for a knocking noise in the engine compartment. After the Lexus dealership in Richmond checked it out, the water pump was going bad (56K What’s up with that, My 02 Honda Accord 287K miles only thing every gone wrong is the alternator [ I have even had 2 timing belts changed with water pump as recommended and they have lasted 100K plus each time] ). After the dealership replaced the water pump while under the 60K warranty, 3 recalls fixed (Toyota / Lexus foot peddle deal, value spring issue, and one other I can not think of right now (there is a code on the work sheet). I picked up the car on 12-22-2011 and drove it up to Northern Virginia. I noticed that the heat in the car was a little cool, but at first I did not think of it, then on the way back I had NO heat and about 20-27 miles back towards central Virginia the car over heats and fluid flows out every where with steam. I had to have the car towed back to Richmond Lexus. The dealership after working on the car stated that the "O" ring got twisted, I am only a back yard mechanic at the best of times and I know my limitations so I do not know how this happens especially with my experience with my 287K Honda V6 Accord (see above). Now the dealership has had the car for since it was towed (now 1-3-2012) and they reported they have fixed the car, test driven it, are going to re-pay for the tow, and that the aluminum heads+gaskets+block is OK. I NEED to know if there is any questions or issues I need to ask them before I take possession of this IS 350 that may protect me 10, 20, 30 K miles down the road of having the items above crack, warp, or just break down due to this overheating and fluids going everywhere, any help would be great. This car only has the standard warranty as I bought it used in July of 2011. I have a call into the Lexus in CA HQ for a customer representative to call me, but NO LUCK so far, way to go Lexus; I should have bought an Acura.
I would like to know what they repaired to "fix" it. Just the o-ring, or did they replace other components? As for the block and heads, if there were damage to them (typically warping), you would know that immediately. That isn't the type of damage that shows up years later. A cracked or warped head would leak as soon as they started it up. Find out what all was done to it, if and how they plan to compensate you for their negligent repair, and if they are willing to extend you any sort of additional coverage based on the fact that you are concerned about more extensive damage.
100,000 / 7 Years? When I spoke with the service rep. they stated my car has a 5 year 60,000 mile power train warranty. I hope I do not understand the service rep and I have the 100,000 mile / 7 year warranty, I will have to re-call Lexus out in Cali. Thanks for the information.
"I would like to know what they repaired to "fix" it. Just the o-ring, or did they replace other components? As for the block and heads, if there were damage to them (typically warping), you would know that immediately. That isn't the type of damage that shows up years later. A cracked or warped head would leak as soon as they started it up. Find out what all was done to it, if and how they plan to compensate you for their negligent repair, and if they are willing to extend you any sort of additional coverage based on the fact that you are concerned about more extensive damage."
From what the rep. stated they just replaced the "O" ring, not the whole water pump and I do not know if they should have replaced the water pump also, if anyone can give a professional mechanical opinion?
F that have them fix it according to lexus:
Powertrain Warranty
The Powertrain Warranty is for 72 months or 70,000 miles, whichever occurs first. Except for the situations listed on the Basic Warranty page, this warranty covers repairs needed to fix defects in materials or workmanship of any component listed below:
Engine
Cylinder block and head and all internal parts, timing belt and cover, flywheel, oil pan, water pump, fuel pump, engine mounts, engine control computer, seals and gaskets
Transmission and Transaxle
Case and all internal parts, torque converter, clutch cover, mounts, engine control computer, seals and gaskets
Rear-Wheel Drive System
Differential carrier assembly, driveshaft, axle carrier, axle case, axle bearing, axle shaft, seals and gaskets
See your Lexus dealer for complete details on the Lexus Powertrain Warranty.
Powertrain Warranty
Engine
i didnt know that, thanks fot the info, at 55k last month bought a extended warranty for 30k or 3 years for my 07 is350 which cover lots of stuff plus door ding, tires and wheels
+1, on this. I would take it for a good 15-30 minute drive around the dealership when you pick it up, park it let it cool for a few mins, check for any leaks and then head home and keep a close eye out for leaks for the next few months but you should be good.
I would ask, so...what was the amount of warpage on the heads and what amount of material removed from the heads in order to make them flat again? And I'm sure they'll just say they weren't warped. And then I would ask if the heads were even removed. If they say no (meaning they would need to install new headgaskets), then I would ask how do you know whether the heads were warped or not then? If they say yes, then ask what machine shop they outsourced the measuring to because from what I've read online is that Lexus dealerships don't do in-house machine work and that would include (at least I would hope) the use of a professional straight edge, feeler gauges, and pressure testing machine.
And yes, you can have an aluminum motor seal fine and not leak right out of the service dept but end up breaking down again a couple thousand miles down the road. Ask me how I know with my 9 cross-country trips and personal experience of this happening to me in Denver, CO.
