How To Disable DRL On Is350
#31
For US cars, they can be disabled via Techstream.
For Canada cars, it cannot be disabled in Techstream because the ECU is different. Either you have to do some re-wiring or get the US ECU for it and swap it out with the stock unit, then you can disable with Techstream just lke the US cars.
#32
Why do they need to disable the DRLS in order to install the led headlights?
#36
this thread died, if I buy the techstream below...Can i disable it? I got the 2012 headlights but the ugly DRL's are still on. I need them gone and no1 in VA so far can help me
MINI VCI TIS Techstream v7.31 TOYOTA Diagnostic Tool VCI Tis Techstream : Amazon.com : Automotive
#37
If you buy the ebay techstream unit, you'll need to run it on 32bit winxp. Drivers should be included. Incase you don't have a computer w/ winxp just use oracle vitural box to emulate. There's also this: http://www.ft86club.com/forums/showthread.php?t=7435 Don't know if anyone has tried it on the 2is
#40
Here is a video to help. As far as I know it only works with Windows XP. Like liqB said you can use oracle virtual box to emulate winxp.
https://www.virtualbox.org/wiki/Downloads
