Repercussions of no fender liner?
Old 01-05-12, 08:38 AM
LamTheSham
LamTheSham's Avatar
Default Repercussions of no fender liner?
Hey CL,
I was just wondering what the repercussions of removing the front fender liners would be?
I've already cut out a HUGE amount to be at the height I am - tucking until there's like one tight pinky gap from the rim to the fender, and tucking the entire tire in the rear.
What are the downfalls to removing the fender liner, if any?
Thanks!
Old 01-05-12, 08:48 AM
RDIS250AWD
RDIS250AWD's Avatar
Water, rocks, dirt could fly up in there while you're driving
Old 01-05-12, 08:52 AM
c-low
c-low's Avatar
^^^^ loud annoying rocks chipping away whatever is under there. did it on my old civic.
Old 01-05-12, 09:00 AM
LamTheSham
LamTheSham's Avatar
Aww shoot. So I just have to cut more out, huh? :P
Old 01-05-12, 09:07 AM
Joeb427
Joeb427's Avatar
Moisture in your fogs.
Nevermind,thought you meant the fronts.
Old 01-05-12, 10:22 AM
jbjones85
jbjones85's Avatar
from vehicles in the past the downsides would be water/dirt getting everywhere and the added noise of rocks hitting the metal instead of the plastic.
Old 01-05-12, 12:18 PM
iRock
iRock's Avatar
that would have me so paranoid
Old 01-05-12, 12:56 PM
LamTheSham
LamTheSham's Avatar
Guess I'll just leave the top/bottom area, and cut out some more near the folded fender lip.
Too much rubbing when you're dumped. D:
Old 01-05-12, 01:33 PM
Sffd103
Fire Slayer
Sffd103's Avatar
On my Civic I removed it completely and got water and dirt in the door jamb. I'd say cut the upper most portion and leave the area by the fogs and by the door area.
Old 01-05-12, 01:39 PM
LamTheSham
LamTheSham's Avatar
Will do, Mariano! Thanks!
Old 01-05-12, 05:18 PM
SCWB
SCWB's Avatar
Does removing the fender liner affect the aerodynamic of the car?, i.e. more air turbulence inside the wheel well? I think the liner itself acts as a wind deflector in some sort of way.
Is a little hole around fender-bumper tab ok? Would I get moisture build-up in the fog light?
Old 01-05-12, 05:34 PM
Sffd103
Fire Slayer
Sffd103's Avatar
No way dude!! You worry too much!
Old 01-05-12, 06:46 PM
Dexterr
Dexterr's Avatar
Another solution when you remove the fender liners, spray some adhesive foam for protection. I'm not sure where to buy the foam, but my buddy at body shop sprays foam inside the wheel wells on "old" classic show cars, cause some of the classic cars do not have fender liners. The foam forms with the fender/body line, and looks really good.
Now as far as how long the foam (wear and tear) will last, I don't know...guess that will depend on weather, and how much you drive your car. As I mentioned, he only sprays the foam on classic show cars, which are seldom driven.
Old 01-05-12, 07:22 PM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
If the car is ever outside in moisture, it will trap that moisture between the foam and the inside of the metal panel, causing it to rust from the inside out... Saw someone who did that to keep the car from rattling because of a very loud stereo, after a few years, you could see where it was done from the outside - the panels started just falling apart...
Old 01-05-12, 07:38 PM
Dexterr
Dexterr's Avatar
I think my friend seals the foam - to prevent moist and rust. But again, no guarantee from that happening.
Quick Reply: Repercussions of no fender liner?
