ISF wheels?
Old 01-05-12 | 11:12 PM
redmethods's Avatar
redmethods
Default ISF wheels?
Will the wheels of a ISF work with a IS250 AWD?
Thanks
Old 01-05-12 | 11:14 PM
lobuxracer's Avatar
lobuxracer
Tech Info Resource
No. The offsets are all wrong.
Old 01-05-12 | 11:18 PM
redmethods's Avatar
redmethods
****, Thanks anyway.
Old 01-06-12 | 12:55 AM
GiantsFan's Avatar
GiantsFan
It's been done before... from what I read you will have some minor rubbing on the front fender liner.
https://www.clublexus.com/forums/is-...-is-250-a.html
Old 01-06-12 | 07:22 AM
Mancebof's Avatar
Mancebof
[QUOTE=GiantsFan;6926947]It's been done before... from what I read you will have some minor rubbing on the front fender liner.
Even if its not dropped? Is the lug pattern the same?
Old 01-06-12 | 08:05 AM
MoarLow's Avatar
MoarLow
[QUOTE=Mancebof;6927195]
It's the same lug pattern.
Old 01-06-12 | 08:28 AM
Mancebof's Avatar
Mancebof
[QUOTE=MoarLow;6927260]
So considering the car isnt dropped they should fit?
Old 01-06-12 | 09:21 AM
100degrees's Avatar
100degrees
They will fit, rubs the inner fender liner a bit if you dont heat gun the liner. Otherwise, they work fine.
Old 01-06-12 | 12:47 PM
DaveGS4's Avatar
DaveGS4
Forum Administrator
Do you know what the difference is for the OP's AWD vs the RWD IS250 in the picture you linked?
Old 01-06-12 | 12:59 PM
GiantsFan's Avatar
GiantsFan
Oh... Overlooked the fact his is AWD
Thanks for pointing that out Dave...
I am not familiar with the AWD differences.
Old 01-06-12 | 11:42 PM
robertrios's Avatar
robertrios
should fit but you should go with the same size all around...prob rears all around to be more flush. Heat gun to get rid of the rubbing.
PAVGR
05-09-16 08:19 PM
Sirguy01
04-24-16 05:58 PM
Mistr2
04-14-16 12:31 PM
Emprado
IS F (2008-2014)
12-28-15 07:37 AM
LEXUSF
Club Lexus Vendor Marketplace
02-12-10 10:59 AM
