Flyaudio gps screen freeze and fitment issue
So I installed my flyaudio unit about a week ago and I love it. But I have some minor issues. I ordered it off of ebay and when I recieved it, it didnt have the mini sd card. So I used my own sd card and loaded a gps program. But it didnt work..Now when I turn the unit on and hit the navi button, it goes to a blank screen. The top of the screen has a scrambled like that goes across it.
Also, after I hooked everything up and put the unit in the dash, i found that I couldnt get the vents to fit back in. Theres about a tenth of an inch of lip that goes over the top of the unit from the vents..almost like the nav unit was too tall. Anyone else have any issues like these? I really want to get this fixed.
ok try this to start the unit. before you start the engine, put one of your finger in the middle of the screen and start the engine and continue to press on the screen. then you can calibrate your unit by a tap on the upper left corner then the lower right corner. see if that works
On the fitment issue, I got a 2-mm gap on the right side. Ohter than that, it fit fine.
Your issue may be caused from using mismatched model with your car (06-08 is different for 09-10 model)
Well now I'm just pissed! I thought they were pretty much universal and when I bought it I figured crap like this wouldn't happen.
If this is the first Gen model you may want to update the Bios and see if it fixes it.
I had a similar issue except it was not uploading the nav from the original sd card. I reinstalled the Bios and it fixed my issue.
Here is the instruction on how to do the install .
http://www.flyaudio.us/forum/12-tech...e-instructions
and the bios software is here .
http://www.flyaudio.us/forum/16-down...-e8039-a-e8041
Hope it helps.
Hope it helps.
Well I wasn't sure what gps software to use but I read that igo8 worked well so I downloaded it from a torrent (not sure if that was legit) and used it. Could you pm me a good link to get a good gps software with maps?
I have the first gen unit..so all I need is the update I hope.
