DIY - for an oops moment. Tried to replace cabin air filter without setting to circ.
#61
Hi all, I've really enjoyed the forums and they have helped me tremendously. I too broke my fresh air damper assembly on my ISF and glued it back together. This broke also so I dove in to fix the door correctly without removing the whole blower assembly.
I ordered PART #8702030020 which came with the pivoting door and a new arm. Here is what I did.
1. Remove kick panel, knee airbag, and glovebox
2. Remove the 2 black screws that hold a duct and an electrical box. Move both to expose the broken arm on the end of the rotating door.
3. You will see 4 silver screws with the heads pointing down that hold the top half of the door housing to the bottom half. Remove.
4. You will see a 10mm bolt on the top-right half of the housing. Remove.
5. There is a Phillips screw with the head pointing to the drivers side on top of the housing. Very hard to get to, but remove this screw as well.
6. Pull apart the upper housing at the split in the middle. Be careful but the left half will move quite far. It helps to reach toward the firewall and undo a plastics clip holding the housing together.
7. Wiggle the old door out and the new door in. I pulled the left hinge out first and then the right. Take your time.
8. Install the new door arm with a click. Reassemble and test.
This took me about 45 minutes to do and cost around $35. I hope this helps someone that is handy and who doesn't want to glue their ISF back together.
#62
I wish I would have taken pictures. You must make sure you separate the top half of the housing from the bottom half by removing all screws and clips. (There is one near the firewall on the drivers side too) Then split the top half in 2 at the middle seam. (There is a hidden screw near the windshield that you need to remove). Make sure you remove all screws you can see, even the 10mm bolt that attaches the top half of the housing to the dash metal. Once you do that, the left half moves quite far and will clear the door arm stud. The right half doesn't move as far. You may need to squeeze the door together a little too.
#64
Pretty much what Cwajciec says, but after removing the screws, you need to separate the upper 1/2s from the lower housing by prying it up, and then separate the upper 1/2s to get the door out . The 1/2s are not removed from the car, just split enough to get the door out. That top screw is also tricky to get out, but it can be done. I did not put that screw back in.
#66
Thank you for the DIY project for the recirculating door issue. When I got my 2006 IS350 back from the Lexus of Roseville dealership for the dash recall, it was noted the recirculating door was broke. It worked before they touched it. So I have this project to do. Also the dealership damaged the trim around the NAV system. I am not happy about that either.
#69
Hey Guys,
I'm going to be attempting this DIY fairly soon, but I just have a couple of quick questions. Is it possible to just attach the broken plastic arm that comes from this part number? 87020-30020
#70
Oh damn you might have found the part. I'm not too sure, Google pics showing pictures and stuff of varies things. I think my piece is missing please post a DIY, this problem is so annoying @.@
#71
thanks guys... driving in to work today... weird buzzing noise....this is it. I'll work on it this weekend. must have broken (or come off track, depending on what I find) while driving. I've always done the recirculate thing and I haven't changed it in months. oh well "stuff" happens.
great write up
great write up
#72
great write up
great write up
#73
yea the piece blocking to the entrance to door is quite slim... I'm not sure if the door opens when u put it in recirculation mode or fresh air mode... because my door is broken... actually It problem is suppose to be up when you're in recirculation mode because when you change it, it should be moveable or up haha... FML
