Would a limited slip differenital (LSD) help me in this situation?
#31
So far this winter......yup probably not needed. However, last year we had 8 big storms in a row. It was WELL worth the "extra" (but then again i didnt pay extra for it) $$
#32
From this guys video....with snow tires......tell me AWD wouldn't be a better choice? I'm just starting up the old awd vs rwd argument, where people say AWD IS models are stupid and pointless and have NO advantage over RWD because if you KNOW what you're doing you can handle snow just fine.
You're inventing what is called a straw man. A flimsy argument nobody actually made, just so you can knock it down.
What people have said is that the places AWD does offer an advantage in a sub 400 hp car are very, very very narrow and limited... and they come with a lot more dis advantages that are relevant more often and more significantly.
That's what I've said, that's what the other guys getting around just fine in the snow with RWD have said.... it's what Car and Driver and others have said based on actual testing of RWD vs AWD.
Because that's true.
On the other hand, the AWD car will cost several grand more upfront, be slower than the RWD off of snow, give you inferior mileage 100% of the time. It will also be inferior in the snow for both stopping and emergency handling.... you know, things that avoid accidents.
Which is worse, a car that if you're not an experienced driver you might have trouble getting moving up a hill... or a car you might have trouble not getting into an accident with going highway speeds?
Because the RWD car is #1... the AWD car is #2.... and again that's just the 0-20% of the year there's snow...the other 80-100% of the time RWD wins all categories as well as costing less up front.
But really, if you're just "starting up the old awd vs rwd argument" you should take it one of the old AWD vs RWD threads and bump that, rather than jacking this one.
#33
Yeah! This thread is finally heating up!! Here's some more fuel for the fire! ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
http://youtu.be/bay2axoVt8g
Disclaimer: I live in Florida so I have no snow driving experience whatsoever and I laugh at all the troubles you guys go through just to get around.
#36
