fender tab mod?
Old 01-20-12, 08:26 PM
Krinkles
Krinkles's Avatar
Default fender tab mod?
Hi all! getting close to finally putting my 20's on, i have been searching the forum for days trying to find a diy or pics of some modded fenders so i can be prepared i understand the fender tab has to be cut off and relocated as well as a heat gun on the fender lining but is there an actual diy or pics out there? i tried the search so i had to ask thanks in advance guys!
Old 01-20-12, 11:19 PM
1herm4
1herm4's Avatar
dang i just finished doing this 15 minutes ago. i should have taken pics!
Old 01-21-12, 10:41 AM
Krinkles
Krinkles's Avatar
Can you maybe snap a pic of what it looks like complete?... Is it just pretty much cutting the metal tab where the fender meets the bumper then drilling a hole and securing it with a clip or tie wrap?
Old 01-21-12, 12:50 PM
LexGirl33
LexGirl33's Avatar
Would like to know too.
Old 01-21-12, 03:44 PM
Dvo
Dvo's Avatar
Me three
Old 01-21-12, 04:02 PM
kumquatism
kumquatism's Avatar
These aren't the greatest of pictures, but it's pretty difficult to take pictures without removing the wheels. There are certainly other ways of doing the tab modification, but this is what my car has.
It should give you a general idea of what needs to be done.
Old 01-21-12, 04:13 PM
Krinkles
Krinkles's Avatar
ahhh perfect! so its pretty much just the upper tab that needs to be altered?
Old 01-21-12, 05:39 PM
ccdan
ccdan's Avatar
I cut my tabs completely off and just use the black snap in deals. Works fine and haven't had any issues highway driving and all.
Old 01-21-12, 05:55 PM
1herm4
1herm4's Avatar
i only had a slight rub so i made a relief cut after removing the bolt and bent the mounting tab all the way back. then i cut and trimmed the reaming sheet metal. placed a self taping screw....no rubbing now.
Old 01-21-12, 05:58 PM
Vroomin350
Vroomin350's Avatar
Krinkles it's the tab where the bumper meets the fender. Take off the OEM screw from the factory position, dremmel/cut cut off that section and place another bolt further up. Are your fenders rolled?
Old 01-21-12, 11:16 PM
Krinkles
Krinkles's Avatar
oh ok great i get it now thanks for cleaning that up.. at the moment theyre not rolled yet but when the suspension goes on (Megan LP) with the wheels they will have to be ..... i will be running..
REAR 20"x10 +35 .... 255/30/20
Front 20"x8.5 +35 ..... 225/30/20
Old 11-12-12, 12:47 PM
dorkacho
dorkacho's Avatar
oh thanks guys! very useful!
but still a little confused where fender tab is..
Old 11-12-12, 05:51 PM
SCWB
SCWB's Avatar
Hi Krinkles, from my experience, with your proposed set up, you might not even have to relocate the fender tab at all.
I have 19x8.5 +35 with 235/35/19 which is 10 mm. wider than yours. Mine also has taller overall diameter of 25.47 inches versus 25.31" of yours. I only have very very faint rubon the liner which can be cured by heat gun (so minor I didn't even feel when it rubbed!). Considering your set up is both shorter and narrower, you will be very safe unless you slam your car to the ground.
Old 05-17-13, 05:45 AM
LexoticJ
LexoticJ's Avatar
mine is rubbing on my 20s after lowering on BC Coilovers.... and its definitely bent the crap out of this tab..... any pics of how you guys cut and bent or secured this piece would be helpful.... i appreciate the pics above to help locate the problem
Old 05-17-13, 08:12 AM
maximL
maximL's Avatar
I'll be taking off my front bumper tonight. I'll take pics of my fender tab. But the fender tab is right where the fender meets the bumper. There is a bolt holding your bumper that needs to be removed. I actually cut the metal tab about 5mm on each side with an air grinder and then hammered it up and out of the way. Bumper stays in place with a zip tie.
Quick Reply: fender tab mod?
