My First show off thread, here it goes
wassup clublexus fellers i have been lurking clublexus post for about a year i have a 2008 is250 AWD , and i think its time i contribute ...this is a show off thread and if you guys got some tips/ ideas lmk im all ears , first off my wheel specs are 19x8.5 +39 f and r is 19x9.5 +45 wheels are 235/35/19 and 275/30/19 i know i coulda got a more aggresive setup but i got a good deal on the wheels and couldnt let them pass but here it goes
first off gata thank memoryfab for the sexy wheels here they are finished and ready to be shipped
[IMG]
[/IMG]
this is my daily drive height
[IMG]
[/IMG]
[IMG]
[/IMG]
and for some damn reason i still be rubbing on small dips and im not that low so mabe you wheels guru's can help me out with suggesting better tire size for the awd i have done some reasearch and lots of you AWD guys do it up big but i am still worried about destroying my awd system with a staggerd setup is why i went with the 235/35/19 and 275/30/19 and i am tired of rubbing and i want to be lower so if you AWD guys can help suggest better tire size so i can go lower im all ears.....this is how low i want to be... i was board so i lowerd my car to see the height i want
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
this is how low i want to be by the summer i am hoping i can find someone in the summer to do a pull on my fenders so i can drop lower and i am also waiting for the summer to put my wheels and 2011 F sport bumper on because winter sucks
[IMG]
![](http://i1123.photobucket.com/albums/l541/andyhoong/memoryfabwheels.jpg)
[IMG]
![](http://i1123.photobucket.com/albums/l541/andyhoong/IMAG0024.jpg)
[IMG]
![](http://i1123.photobucket.com/albums/l541/andyhoong/IMAG0013.jpg)
[IMG]
![](http://i1123.photobucket.com/albums/l541/andyhoong/IMAG0051.jpg)
[IMG]
![](http://i1123.photobucket.com/albums/l541/andyhoong/IMAG0050.jpg)
[IMG]
![](http://i1123.photobucket.com/albums/l541/andyhoong/IMAG0048.jpg)
[IMG]
![](http://i1123.photobucket.com/albums/l541/andyhoong/IMAG0042.jpg)
[IMG]
![](http://i1123.photobucket.com/albums/l541/andyhoong/IMAG0035.jpg)
and sorry for crappy cell phone pics i do not have a good camera nor am i a good photographer ahha but i want to be able to tuck my tires in so if you guys can help me out i would really appreciate it
Nice. I have an AWD and i have wheel specs very similar to yours, however they are not mounted yet. But I've done tons of research and have found out 225/35/19 front and 265/30/19 rear is best. I'm almost positive it will get rid of your rubbing issues.
Idk too much about the AWD fitment, but as far as tire sizes, 275s are causing the rubbing. Width and offsets of your wheels are not aggressive at all, so it should be the tires. I'd probably run a 225/35-19 and 245/35-19. Have your fenders rolled flat, cut your fender liner and natural camber should take care of the rest. You'll be able to tuck. :P
I'm on a 19x9.5/10.5 +22 225/35-19, 245/35-19, rears are almost fully tucked (rolled flat and a slight pull), and fronts are slightly tucked (raised to no gap now because of fender damage but rolled flat with slight pull).
Car looks great too! Dump it and DD it.(:
i was planning to run 235/35 front and i was gana do that to the back also so that i have all same tire size but the rear would look stretched while the fronts wont be but my rubbing problem is more in the back would this work or would it be ugly to have the rears stretched and not the front or mabe 225/35 all around ? so i can tuck the fronts in more also
I wouldn't even call that a stretch. One size is nothing. You still have plenty of rim protection. I wouldn't do 225 all around because then it'd be a serious stretch. You could do it if you really wanted to, but I wouldn't recommend it. The fronts wouldn't even really look stretched, and the rears would look aggressively stretched. Just go with 225/245 or 225/255
Lam with the awd your very very limited to certain size tires. Cant just threw out tires size cause they work on the rwd version and yes it safe to run the size i said. Those are close to the stock rolling diameter. Plus If you wanted to run the same tires all around then you shouldnt have gone stagger.
225/35/19 with 265/30/19 is closer to the same overall diameter. You can check for yourself in a tire calculator. Discount tire shouldnt care, cause these tires are slightly cheaper than the sizes you currently have on.
