tires & rims... need your help...
Hi guys,
please help me choose the correct set up for my car.. and WHICH RIM WOULD LOOK GOOD? Do I need to run stagger or Can I run all the same size rim all around?
is350 rwd.. tungsten pearl color..
1. Ace Strada
F-19x8.5
R-19x9.5
2. Petrol Vengeance
F-19x8.5
R-19x9.5
Rim 1&2
F&R.. 19x8.5
or
F&R.. 19x9.5
Tire:
Front: 225/35ZR19XL 88Y B
Rear: 255/35ZR19XL 96Y B
1. Ace Strada
F-19x8.5
R-19x9.5
2. Petrol Vengeance
F-19x8.5
R-19x9.5
Rim 1&2
F&R.. 19x8.5
or
F&R.. 19x9.5
Tire:
You need to list the offsets too. Definitely go staggered
both sets are pretty much the same except one with more spokes, I'd go with the ACE
my current wheels for the winter now are
Front:19x8.5+20 Rear: 19x9.5 +15
215/35/19 and 245/35/19 running on coils, rubbing at big bumps, all fenders rolled.
if you gonna run 225 and 255 you probably gonna need those wheels to be in the 25-30 offsets with fenders rolled
also check here:
https://www.clublexus.com/forums/is-...tart-here.html
also check here:
Do you want rubbing? Do you want to have to do fender work?
A lot of members on here go with FORM > FUNCTION. Thats cool, and it may look good ... but thats not me... Personally I like being able to drive the crap out of my car.
Id go with...
19x8.5 +30 235/35/19
19x9.5 +35 265/30/19 or 265/35/19
And honestly Id even say you can go +35 in the front. (The lower the number - the more aggressive the offset)
Wheels are FLUSH (NOT hellaflush!!!)... NO fender work, NO rubbing, and still LOOKS GOOD. (Im lowered 1.4" front and 1.3" rear)
Everyone is going to have their own opinions on what the "best" setup is... some people like tucking with tons of camber... some people ride flush ... some people go hellalush. Its all a matter of what you like.
Id go with...
here more info on the rims.. I couldn't find the offset number so please help me out.. I"m also going to drop the car w/ f-sport spring and I don't want to roll the fender..
Ace Strada
Size 19X8.5 5-114.3 38HBM
Diameter 19″
Width 8.5″
Bolt Pattern 5-114.3
Size 19X9.5 5-114.3 38HBM
Diameter 19″
Width 9.5″
Petrol Vengeance
Size 19X8 5-114.3 40HSS
Diameter 19″
Width 8″
Size 19X9.5 5-114.3 40HSS
Diameter 19″
Width 9.5″
Ace Strada
Diameter 19″
Width 8.5″
Diameter 19″
Width 9.5″
Petrol Vengeance
Diameter 19″
Width 8″
Diameter 19″
Width 9.5″
search/google much?
the ACE Strada wheels only come in the following specs:
19 x 8.5 +20
19 x 9.5 +25
(http://www.acealloywheel.com/mesh-wh...el_1_1039.html)
you'll need to roll your fenders and run 215/35-19 + 245/35-19. no exceptions.
Petrol Vengeance comes in the following specs:
19 x 8 +20, +40
19 x 9.5 +20, +35
given those widths, @ +20 offset you'll need rolled fenders and 215/35-19 + 245/35-19.
@ +40/+35, you can run 225/35-19 + 265/30-19 (or 265/35-19).
http://www.petrolwheels.com/petrol_m...ece_wheels.php
http://www.petrolwheels.com/app_guide/index.php
so, if you don't want to roll your fenders if you're looking at either/or of the two wheels, you only have one choice given the specs.
19 x 8.5 +20
19 x 9.5 +25
19 x 8 +20, +40
19 x 9.5 +20, +35
running a staggered set-up has nothing to do with why you have to get your fenders rolled.
running wheels that are wider than the widths of oem wheels AND considerably lower/aggressive offsets means that you have to get your fenders rolled.
if you go with...
19 x 8 +40
19 x 9.5 +35
you won't have to roll your fenders
based on the two wheels you're looking at, only the Petrol Vengence has those specs.
also, you might want to e-mail/call the manufacturer and find out if 19x8 +40 clears the IS350 front brake calipers. if not, you'll have to run spacers to push the wheels out, which will effectively lower the offset of the wheels.
if you go with...
19 x 8 +40
19 x 9.5 +35
BatLex
Wheels, Tires & Brakes Forum
05-19-07 01:13 PM
