Right HID Fog Is Out
I have a problem with my HID Fog Kit and I was wondering if anyone else has encountered. I have searched and it seems like most people have had flickering and both go out but not just one side.
I ordered DDM 35 W Slim Ballast kit and installed it last summer. That kit lasted until about a month ago when the right side when out. I checked the fuses and the bulb and ballast and it seemed like that ballast was bad, so I ordered the same exact set from DDM. Now the new set has been in for about 2 weeks and I noticed last night the right side on the new set is out again!
Has anyone encountered a problem like this? Do the fogs run on separate fuses? I am just confused if I am missing something when trouble shooting. This weekend I am going to try and switch ballast and bulbs to see if I could locate the issue. If anyone has had this problem please let me know because I am just becoming frustrated with this. Thanks!
This happens to me. I got the Phillips 6000k HID conversion kit,
my right side (if the set to automatic w the fogs on), most of the time doesnt turn on
If i manually turn on the headlights or parking lights and then turn on the fog light that sometimes works. but essentially its a pain in the ***,
does anyone know why this happens? or how to fix it?
You probably need a harness to hook it in because it's not getting enough power.
I too am using the Philips Ultinon conversion kit however don't have issues with it and I use these with the auto setting with the headlights.
Did u use a harness with ur phillips?
yesterday, both lights stopped working, and then when id turn it on and off the right one came one alone. lol very wierd.
