30 degrees outside, interior temp set at 70, cold air is blowing instead of heat. Have to turn the climate control off because it keeps blowing cold air instead of hot. Any ideas?
Just like neomedic said let the car warm up, the heating system works of the hot collant. If the engine is not up to operating temperture the collant can't heat up the coils so the blower blows warm air.
what mode do you have it in? Anything with the defrost symbol included turns on the AC condenser to help remove humidity from the cabin even though the their is no indication the AC is on.
I sometimes notice cooler air blowing when I have to switch to a defrost mode for whatever reason.
