2007 is 250 footwell lights HELP
Everyone seems to be more than happy to assist in the post I have been searching but nothing was directly related to my issue, so I decided to register and plead for help. I promised I searched up and down CL and could not find a DIY to wire up or change the light on the floorboard. I just got my 250 and have been trying to change all the interior lights LED blue. Can anyone please help?
Everyone seems to be more than happy to assist in the post I have been searching but nothing was directly related to my issue, so I decided to register and plead for help. I promised I searched up and down CL and could not find a DIY to wire up or change the light on the floorboard. I just got my 250 and have been trying to change all the interior lights LED blue. Can anyone please help? ![Sad](https://www.clublexus.com/forums/images/smilies/sad.gif)
My door lightsbare white with a red cover. I was told you can order a different color lens from precisionled.com. They actually helped out alot with the install of my puddle lights
Thanks to ng123ray, I found some pics on how to change the floorwell light. The only hard part is popping out the light and removing it from the connector. From there it was pretty easy.
]![](http://img.photobucket.com/albums/v395/lito_ray/IMG_6215.jpg)
There are two screws on the driver side dash, remove those and partially remove the dash so you have more room to work with. From there, just push UP hard on the LED untill it pops free. It will take some maneuvering but from there you can pull the whole LED assembley out.
![](http://img.photobucket.com/albums/v395/lito_ray/IMG_6220.jpg)
From there just unplug it.
![](http://img.photobucket.com/albums/v395/lito_ray/IMG_6228.jpg)
I ended up taking a small flat head and removed the black peice where the light is connected.
![](http://img.photobucket.com/albums/v395/lito_ray/IMG_6227.jpg)
Inside is a capacitor and diode, i clipped those and removed the leads from the LED so i can still use the orginal plug. I will try to post more detailed pictures once i get a chance. Hope this was helpfull!
