HID Question
HID Question
So i have a 2007 IS250. It has OEM HIDs in it. The driver side ballast is going bad, cuts out and i have to cut it on and off 3x to get it to stay on. I have been looking for a aftermarket kit to replace it all seeing as I want 6k any ways. Everywhere ive looked says they dont sell any that replace, they just convert from halogen to HID. Can you guys post up some links for me? I need to resolve this ASAP and its getting quite frustrating.
Thanks Shawn
Thanks Shawn
Keeping it Real
Lexus does not sell the ballast separately, because it is not possible to remove/replace the ballast without disassembly, which Lexus does not recommend. The ballast cannot be removed because the AFS motor is in the way. You either need to disassemble the ballast connector, or heat up the lights and separate the lens and disassemble the headlight to get the ballast changed. Ask for a ballast for a 2011-12 IS, it will work fine. , but you will need to dissemble something, there are videos on YouTube showing how to take the headlight apart, and JoeZ recently posted pictures of how to take the ballast apart.
Jeff
Jeff
