CRZ headlight
you can do this.
Open up your headlight and do a retrofit. Paint the inside of the projector bowl : the cutoff shield, facing away from the bulb.
It will reflect blue or crystal clear in certain areas due to the lens. I have clear lenses on mine so they are really great for clarity. You could do it to your stock projectors if you take them apart. You could also spray the area around your projector housing. Either way requires you to open up your headlight housing.
