water leaking inside...?
Hi
Lately I have noticed that on rainy days I have a little leak inside my car.
The water coming into the car through A post. My quess is the leak has a place right under windshield drip side finish molding on a passenger side. The windshield drip side moulding has a bad rubber and I am wondering if I replace only that side moulding it going to help or it may be bad windshield seal and I would have to cut out the whole windshield and seal it back again?
In addition I can say that the other side has bad side windshield moulding rubber too but there's no any leak...
I would check the drainage holes in the sunroof. The left side more than likely is clogged up and so it may cause the water to overflow and leak instead of draining out. Had a similar problem on an old corolla I had, just needed to clean out the tube and hole and it was all good.
My dad's ls400 had a problem where in the back the trunk would collect water, and that was because the drainage tube had slipped out of the hole in the back and was pouring water into the trunk....
sNotM3 (06-22-24)
Hi
That said, I'm not entirely sure that replacing that molding would fix your leak. I have a suspicion that that molding is not the only barrier to water in the A-pillar structure. I suspect that if you take off that windshield molding (which you or your dealer should do regardless, to replace it) you'll find a different issue. Maybe a bad seal with the windshield. In any case, I wouldn't think itd be a super expensive or complicated repair to reseal that area. But I don't know. Hope this helps!
sNotM3 (06-22-24)
Which one is better for you is a choice that's up to you and only you tho.
I'm glad you had 0 issues with your BMW tho, most of the BMW owners I know wish they had that kinda luck with a BMW!
sNotM3 (06-22-24)
89supra884
SC- 1st Gen (1992-2000)
07-19-12 06:15 PM
