vsc off
Old 02-19-12, 01:12 PM
Denver
Denver's Avatar
Default vsc off
ok, so pressing the button once and then holding it for 10 secs. does this disable everything 100%?? i did this and a buddy of mine tried to do some drifting and he said he can feel the diff locking up and the car doesn't disable vsc 100%. can anyone enlighten me about this?
Old 02-19-12, 01:16 PM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
Press and release = TRAC Off, VSC On, ABS On.
Press and hold for 3 seconds = TRAC and VSC Off, ABS On.
Essentially yes, with TRAC and VSC off, everything is off. It is entirely off.
Jeff
Old 02-19-12, 01:55 PM
YoNadz
YoNadz's Avatar
y don't both tires burn when I roast em'?
Old 02-19-12, 01:59 PM
laobo979
laobo979's Avatar
Cause these car dont come with LSD....
Old 02-19-12, 02:00 PM
Denver
Denver's Avatar
really, we don have lsd??
Old 02-19-12, 02:01 PM
Denver
Denver's Avatar
Jeff
no, i dont think its off 100%. there are three lights, one on the display saying trac off, one on the left side of the cluster, and one on the right side of the cluster. the one of the right needs to come on too.
Old 02-19-12, 02:08 PM
Sango
Sango's Avatar
Yes, the cars don't have LSD unless you are willing to put an aftermarket one, then yes.
Old 02-19-12, 03:57 PM
VIS250P
VIS250P's Avatar
I turn VSC off and yes it feel different... The car can drift
Old 02-19-12, 05:00 PM
UniSlayEX
UniSlayEX's Avatar
Press and release it desables TRAC but VSC remains on; Hold it for 3 seconds and both TRAC and VSC will be disabled...
Old 02-19-12, 05:36 PM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
Nope.
That light tells you when the VSC or TRAC is operating. When VSC and TRAC are off, it will not come on.
Jeff
Old 02-22-12, 11:41 AM
Denver
Denver's Avatar
^^^ yeah, i did that. a buddy of my tried to do some donuts and he said "open diff' so i guess its because ISx50 doesn't have LSD. Im really disappointed now
Old 02-22-12, 12:16 PM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
Your ISx50 has a semi-LSD, that is there is a preload mechanism that provides some of the characteristics of an LSD at low speed/low torque. This helps if you get stuck, but does virtually nothing at higher speeds (this would include 'doing donuts').
Jeff
Old 09-06-12, 11:31 AM
jgarrido
jgarrido's Avatar
for what MT use VSC?
Old 09-06-12, 11:49 AM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
I'm sorry, that doesn't make any sense.
Can you rephrase the question?
Jeff
Old 09-06-12, 04:10 PM
jgarrido
jgarrido's Avatar
hi jeff, (sorry iam spanish guy) the throttle on manual transmission is terrible, my question is the VSC off would improve?
thanks...
Quick Reply: vsc off
