Brake Fluid and Spark Plug Threads? HELP!
Okay, i've been searching for hours trying to find GOOD threads on repacing the Spark plugs, and Brake Fluid on my 2007 IS250 for it's 60K service.
Can anyone PLEASE give me some good advice or links! Much Appreciated!
It's not that hard to do once you get into it and start unbolting things...biggest thing is make sure you have all the tools and replacement gaskets for the job.
And I guess, i'm just scared i'll do something wrong and be stuck with a dead car at my house!
For Brake Fluid...
I suggest ATE Superblue Brake Fluid
and if you going to a brake fluid flush, maybe you should consider running some stainless steal lines..
in a sense both a mods but yet will improve brake feel and IMO safety of the vehicle, due to less flex in the lines when you are in a situation where you have to do an immediate stop, less flex, improve braking but to totally improve braking you gotta change the brake pads
But just good fluid and lines alone are still an improvement over stock
ATE Superblue Racing fluid is great, if you don't want the blue though, or want to be able to tell you've flushed the lines, consider TYP200 as well, it's the same fluid, but yellow instead of blue. That way you can alternate between Superblue and TYP200 and be sure you've got all the old stuff out.
Jeff
Jeff
Don't waste your money on expensive brake fluid unless you track your car. Sure, ATE and Motul (Brembo, Castrol, etc.) make great fluid, but you;ll never know the difference between these and Wal-Mart Supertech if you don't track your car.
The easy way to tell you've successfully flushed is simple - brown fluid is bad. Clear fluid is good.
If you are truly afraid you'll break your car, spend the money and have it done by a professional. I don't do this, but I grew up with race cars and engine builders. Nothing on a car scares me to fix. If spark plugs replacement scares you, it's really not something you should consider doing yourself to save a few dollars.
+1 for ATE Super Blue, we use that on all the DE cars at our shop and for the price ($18) it can be beat. If you have an extra pair of hands a brake flush is not hard at all, just make sure you start from the wheel furthest from reservoir and work your way to the one closest to it, also I don't like pumping the brakes while bleeding brakes on ABS cars, just put pressure on pedal and open bleeder screw and so on, hope this helps
Then again, brake pads won't actually stop the car any shorter either, so you might wanna avoid recommending that as a general to-do too.... the only place they'll benefit you at all is on a racetrack, and not by stopping the car shorter.... just by keeping the same distance over more 100+ mph stops without any time to cool.
If you actually want better stopping, get better tires. The tires are what stops the car.
