sewell offering 2011+ LED headlights for $1200
#182
The much newer REVISED LED'd headlights are a cool white that, to me and vroomin350, are sharper/slightly brighter.
Darrell at Sewell has said these are the NEWER headlights he is selling. But only references that they should not suffer from the paint issue that the newer ones had. He has yet said that they are or are not the revised LED headlights. I'm hoping they are.
#183
The early 2011 LED'd headlights (like most all of us with the LED headlights have) are a warm white when lit at full brightness.
#185
The new flasher relay allows your turn signals to blink at normal speed.. These newer headlights only have Two Amber blinker bulbs.. Instead of 4 found in the 2006-2010 headlights.
Without the new relay.. You will have FAST Flashers... LoL
At the moment all of us DIY'ers and those who buy this kit, are running the LED's at 100% ..
Usually turned ON with one click of the headlight stalk.. They remain 100% when you turn to the second click to turn on the HID's..
We have one member on here who custom wired in some relays and etc etc to get them to work like OEM..
I dont have the time for that..
So mine are 100% all of the time.. when ON
~ Joe Z
~ Joe Z
#186
Check out the posts from Jeff Lange. On another thread, he worked up and implemented a perfect solution to make the LEDs work like stock, like Sewell should have done before calling them "plug and play". You will have to be pretty good with wiring and relays like he is to install. I have his diagram and the parts to make the attempt but just haven't gotten around to it yet.
#189
#193
#195
