sewell offering 2011+ LED headlights for $1200
#31
yea but thats like saying buy the fsport springs before revision just because there is a warranty...if you can avoid it all together warranty or not then thats what a consumer will do. I honestly can say I have never noticed my AFS actually doing anything and yes I do have it so loosing that would not bother me however a blinking AFS will since I am OCD about my cars :/
#36
oh okay then no i dont want to disable auto leveling what a bummer! 600rr05 if you do not have factory HID I would buy the fully loaded lights in order to have factory HID. Its only the people that have HID from factory that are getting the stripped version because we are transfering the "guts" of our headlights into these new housings. Thats where the cost savings is. So if you get the loaded version your buying the HIDs that we already have essentially.
I just want to add for you guys with no AFS (this means everyone without factory HID) this should be a must have mod
#39
Received 1,063 Likes
Originally Posted by Lexus
![](http://www.lexus.com/models/ISF/features/exterior/images/exterior_lighting_1.jpg)
- Bi-Xenon™ High-Intensity Discharge (HID) headlamps are brighter than conventional halogen headlamps, use less energy and last significantly longer. In addition, an auto-leveling feature helps to ensure that the headlamps remain pointed at the proper angle. These headlamps also include LED daytime running lights, which use less energy while adding a dramatic air. The IS F comes with LED taillamps and brake lights. Since they illuminate faster than standard bulbs, they can help give the driver behind you more time to respond in emergency situations.
#44
I just want to add for you guys with no AFS (this means everyone without factory HID) this should be a must have mod![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
