sewell offering 2011+ LED headlights for $1200
#526
I had the TSB 2012 headlamps installed to replace my old lamps from Sewell. But I'm having two issues and hope someone can help:
1. I lost the auto level feature (where the lights go up and down when you first turn them on). I'm told that some 2012 headlamps have this feature (I'm not talking AFS) and some do not. Is this true? Have others lost this function?
2. When my headlights are turned on (not just the LEDs, but the headlights too) there is a faint whining sound coming from the headlamp units. Does anyone know what this is?
#527
Keeping it Real
1. All models with HID/LED have auto-leveling, it should be functional.
2. The whining/buzzing is coming from the ballast, it is normal. Your old ones should have been making the sound as well, perhaps you just didn't notice it? (Unless it's louder than normal).
Jeff
Jeff
#529
From his hidplanet post:
-2011+ LED'd Lexus OEM headlights brand new w/o HID bulbs nor ballast from sewell Lexus $2000 (shipped to LightModz)
-mint condition e30 lenses from paleryder $30 (Bill) (shipped to LightModz)
-mint condition s2k projectors from paleryder $270 (Bill) (shipped to LightModz)
-e30's fitted & cut to mate w/ projectors $25
-brand new CBI/Osram 5k D2S bulbs $175 (won't say from who unless he says it's ok)
-phillips 9011 HIR's $52(couldn't find Toshiba's )
-pre-owned AL Bosch ballasts from TRS $160
-Modification work by paleryder for 55watt boost of the ballasts including potted $85-ish
-H11 relay harness from TRS $30
#530
Is the auto-level motor part of the headlamp itself? Or separate? I'm wondering if the headlamps I got from Sewell are flawed in any way.
I appreciate any help you can provide!
#533
Also, the body shop says it was a simple plug-and-play. Is it possible they installed something/plugged in incorrectly?
#534
I would buy these right now shipped to Canada if I had the money, too bad I do not start work until July - I hope I can get the headlights for this price later this year. :'(
These will fit in a 2008 IS250 no problem right? Read about some fitting problems others had.
#536
Keeping it Real
Sewell said it's possible the leveling is a personalized setting that might have reset to off, and that I may need the dealer to program it back on. Is this a possibility?
Jeff
#537
it is possible something got shorted during installation or maybe the harness wasn't wired correctly. In my 06 IS the AFS fuse is under the driver side dash panel (fuse # 17). It wouldn't hurt to check that fuse if you have an IS with AFS. I pulled this fuse out to get rid of the flashing AFS light and it also killed the auto level.
#538
I went to the dealer today and had the service manager look at my car... he is a car nut and Lexus expert. He had a technician attach a diagnostic tool to my car. It showed an error with reading the auto-leveling motor, but no explanation as to why. No errors for the rear sensors, so that's not it. He also unscrewed the engine cover, and the motors are plugged in fine. And it is not a personalized feature that can be turned off.
The guy was at a loss as to why the auto-leveling was not working. He thought maybe the 2012 lamps that Sewell rewired to fit older cars for some reason may be incompatible with the auto-leveling.
To everyone with the 2012 TSB lights retrofitted... can anyone verify for sure if their auto-leveing is working?
