sewell offering 2011+ LED headlights for $1200
Old 02-27-12, 10:06 PM
  #46
LexoticJ
LexoticJ's Avatar
Originally Posted by greg0126
After you put the discount code in (at the shopping cart) the $600 discount applies.
greg you getting these?
Old 02-27-12, 10:28 PM
  #47
Legend217
Legend217's Avatar
Originally Posted by 600rr05
i swapped out my bulbs for aftermarket HID's do i still need the fully loaded lights ?? im also going to call them tomorrow and check regarding the bubble issue you guys mentioned.
Also can you ask them if stripped set come with relay flasher ?
Old 02-27-12, 10:35 PM
  #48
NimaM
NimaM's Avatar
I love these lights, but considering losing the AFS and seeing a blinking AFS light I still cannot justify spending this amount of money even with the discount
Old 02-27-12, 10:43 PM
  #49
JoshIS408
- - G T V I P - -
JoshIS408's Avatar
are these the DEFECTIVE ones or the new ones after the TSIB? If they are new I wonder how I can get mine replaced? Its been less than a year
Old 02-27-12, 10:48 PM
  #50
ilv1004s
ilv1004s's Avatar
i doubt a dealer will sell you a defective item and then replace it under warranty
silly question i think
Old 02-27-12, 11:16 PM
  #51
NorCalIS
NorCalIS's Avatar
Originally Posted by ms2619
you guys are really hyping this AFS b.s... from what I read it barely does anything because the projectors suck period. my question is are these the non defected bubble ones and if not hows the output, or else I can always get a retrofit with way better projectors and cutoff for that much.
Go drive a 90's gm with halogen headlights on a non-lit curvy road at night and then tell me afs doesn't do anything. Yes the projectors may not be as good as some of the other ones, like my gf's RDX, but they are still great lights, especially coming from a 2008 Subaru with halogens and... You guessed it, a 97 Chevy. Like I said before, if they made the MYLED with AFS I'd be all over em.
Old 02-27-12, 11:18 PM
  #52
CCJ22
CCJ22's Avatar
Originally Posted by robertrios
yea i can confirm, my bros 2011 fsport has Auto leveling the 2012 led is slighly different in color or brightness is the only difference i am aware of aside from the bubbling defect
Agreed the 2012 headlights LED section looks SO MUCH better then the 2011's
Old 02-27-12, 11:21 PM
  #53
Lexs350
Lexs350's Avatar
Damn....did not know about the blinking AFS. I'm also OCD and would drive me crazy. Besides...while backing in my garage earlier this evening broke my passenger JDM (Nigel) turn signal side mirror. Looks like time to upgrade to the OEM side mirrors.
Old 02-28-12, 05:31 AM
  #54
greg0126
greg0126's Avatar
Probably not. I'd like to buy a house sometime this year so I'm taking it easy with the mods.
Old 02-28-12, 07:59 AM
  #55
ms2619
ms2619's Avatar
First bad comparison and second we don't have alot of those in the D.C. area from what Joe Z wrote they do come with the AFS on the 2011's but you will be stuck with the blinking light
Old 02-28-12, 08:10 AM
  #56
mplopez
mplopez's Avatar
Are the LED's at 100% intensity at night with the headlight on? If so is it too bright? I'd hate to have the cops pull me over... =O
Old 02-28-12, 08:12 AM
  #57
mplopez
mplopez's Avatar
Josh how is the LED intensity at night with the lowbeams on? Is it overwhelming brightness or does it go down to 50%?
Old 02-28-12, 08:23 AM
  #58
Joe Z
Joe Z's Avatar
Received 1,063 Likes on 586 Posts
Exclamation FYI for All...
Everyone Please pay attention.....
That is NOT what I wrote...
AFS = Adaptive Front-lighting System (AFS) is found on most 2006 - 2010 Lexus IS's that have the HID Headlamp Housings..
This ALSO includes the Up & Down Auto-Leveling feature...
If you have Halogen Bulb headlamps (non-HID) found in some 2006 - 2012 IS's, you have NONE of these features..
Now for 2011-2012 IS's - w/ new LED Day Time Running Light Strips.....
THERE IS NO AFS feature.... I will repeat it again... There is NO AFS feature...
However, the Auto Leveling Up & Down feature remains.
Anyone Questions..!!??
~ Joe Z
Old 02-28-12, 08:27 AM
  #59
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
hows the output on the new headlights? Wide beam pattern compared to the previous ones?
In my opinion (going from 06-08 HID's to 12 HID's), the new projectors are slightly better. The beam pattern is nicer and the hot spot is slightly lower. The light output is nicer, but the beam is not really any wider. Side-mount projectors like this just can't pull off a very wide beam.
Jeff
Old 02-28-12, 08:38 AM
  #60
istarzan
istarzan's Avatar
I'm with you on this one. I think afs is too much to sacrifice for some leds. Now if i didn't have afs, then I might swap to these.
On a side note, anyone know if the 2013 GS has afs headlights? Just curious why Lexus removed afs to add leds in the IS.
Quick Reply: sewell offering 2011+ LED headlights for $1200
