sewell offering 2011+ LED headlights for $1200
Old 04-20-12 | 11:04 PM
  #631
quang's Avatar
quang
so on the LED headlight, which wire is the "low beam +12V wire"? and which wire is the "ground"?
Originally Posted by Jeff Lange
Honestly the easiest way to wire it up to work sort of like the factory setup is to get an SPDT relay (5 terminals: 30, 85, 86, 87, 87a).
Terminal 30 goes to your ignition power source, 85 goes to the low beam +12V wire, 86 goes to ground, 87 goes to the 50% power on the LED strip, and 87a goes to the 100% power on the LED strip.
This will have the LED's at 100% when the car is on with the headlight switch in position 0 or 1, they will drop to 50% if the headlights are turned on (low or high).
Jeff
Old 04-21-12 | 11:59 AM
  #632
ohiois350's Avatar
ohiois350
Quang, there are three wire from the leds dust cover, so the white wire is the ground, and the black is 50% power
Old 04-21-12 | 03:31 PM
  #633
quang's Avatar
quang
cool, ohiois350 , and what about low beam +12V wire that Jeff was referring to?
Old 04-21-12 | 03:48 PM
  #634
ohiois350's Avatar
ohiois350
I haven't look to that one yet, i was focus on to make the leds turn on when the car start, i just order the 5 terminals relay and will wire up like Jeff posted to see it really work? But it is very easy to find out, all you need the light tester and turn the low beam on and test all the wire from the wire harness of the headlights and you would find out the wire for low beam
Old 04-21-12 | 04:14 PM
  #635
MikeyK02's Avatar
MikeyK02
does anyone else notice their blinkers are a **** ton faster?
It maybe because I havent disconnected the DRL's yet
Old 04-21-12 | 04:17 PM
  #636
d2fresh's Avatar
d2fresh
There should be a relay that came with the headlights which slows it down to normal speeds.
Old 04-21-12 | 04:28 PM
  #637
ohiois350's Avatar
ohiois350
Did u receive the new flasher relay? It should fix that.
Old 04-21-12 | 05:10 PM
  #638
MikeyK02's Avatar
MikeyK02
Wtf? I bought the loaded set....didn't see any relays. Anyone have pics?
Old 04-21-12 | 05:41 PM
  #639
Sango's Avatar
Sango
Here is a pic of the turn singal relay.
The one you have in your car is most likely the green one which is stock which is for 6 bulbs; made in Japan.
The one you should of gotten is the one which is for 4 bulbs which is the one in dark brown; made in USA.
The very light brownish is the stock 4 bulb flasher for the 2011+ cars; made in Japan.
Old 04-21-12 | 05:44 PM
  #640
MikeyK02's Avatar
MikeyK02
yep...i believe I have the green one ARRRRGH!
where can one pick the brown one up
and how hard is the install
Old 04-21-12 | 06:13 PM
  #641
Sango's Avatar
Sango
The turn signal flasher is easy to install. Getting there maybe a bit of a challenge. You need to remove the kick panel where the pedals are to get access. Then it will require you putting your head where your pedals are lying down and using your hands to reach the turn signal flasher which is up inside attached to a support thingy which is easy to remove.
Assuming you ordered from Sewell, they should of sent this to you. If not, tell them the turn signal relay was not included and need to have this. If it was from else where you need to go buy it from a Toyota/Lexus dealer or just order from Sewell separately.
The part number is 81980-06020 which is the USA one.
Japan one is 81980-30170 however it's not available in North America (it would say super superseded by US part#), however it is available outside since they will come in brand new cars from the factory. Probably cost savings so they had a US made one as well.
Old 04-21-12 | 07:48 PM
  #642
MikeyK02's Avatar
MikeyK02
Sango you're awesome!! I just emailed Sewell to see what I can get done
anyone have any idea why my friggin fog lights aren't working?? I swear, you think you're getting closer just to find out your even farther away
Old 04-22-12 | 12:06 AM
  #643
quang's Avatar
quang
didn't you plan to hook up to the IG2 fuse? That's how I did for now. But I like the solution of being able to run100%|50% better, keep us posted
Old 04-22-12 | 07:51 AM
  #644
ohiois350's Avatar
ohiois350
Yeah I bought the add on circuit fuse line and add from the ig2 fuse run straight from there, but i just order the 5 terminals relay will try to hook up like Jeff posted I'll you update when I done with it and hope it would work
Old 04-25-12 | 06:07 PM
  #645
NimaM's Avatar
NimaM
Does anybody know if the loaded set came with similar 06-08 MY ballasts? If not, what's the part number?
Thanks
Quick Reply: sewell offering 2011+ LED headlights for $1200
