sewell offering 2011+ LED headlights for $1200
Old 04-26-12 | 07:01 PM
  #661
Rufio808's Avatar
Rufio808
Alright, I'm on the fence, Just want to know if it is easy to take out the bulb that blinks in the gage cluster :/
Old 04-26-12 | 07:08 PM
  #662
ohiois350's Avatar
ohiois350
Originally Posted by quang
You have to cut your headlight bracket
https://www.clublexus.com/forums/7170863-post604.html
or buy a pair of 2012 brackets which then would be direct fit.
part#:
52116-53070
52115-53070
Hey Quang, I thought the 2012 bumper brackets only fit one 2011+ bumper?, but he has 07 is, and it is different bumper.
Old 04-26-12 | 07:48 PM
  #663
quang's Avatar
quang
hehe... ohiois350, I know the part# for a reason, they fit perfectly on my 06
Old 04-27-12 | 05:31 AM
  #664
B16da9's Avatar
B16da9
It's not a bulb it's an LED which you can't take out. The best thing to do is get some black tape open up the cluster and block the light from the inside so it does not shine through.
Old 04-27-12 | 06:19 AM
  #665
ohiois350's Avatar
ohiois350
so those parts number are the one for the new headlights to fit the older bumper like 06-08? all three screws and the brackets line up perfectly with the headlights and bumper? so how much is it cost? thanks quang fro the parts number
Old 04-27-12 | 10:04 AM
  #666
quang's Avatar
quang
The brackets are factory OEM 2012 headlight brackets (sewell sells those too), not specifically made for sewell LED headlight on sale here. and yes, all 3 screws and little tabs on the headlight near the screws line up 100%. I did not want to do the cutting, and bought a used bracket to try out, and turned out to be perfect fit on my 06 bumper
The pic shows why the cutting is not needed if using 2012 bracket
Old 04-27-12 | 10:10 AM
  #667
ohiois350's Avatar
ohiois350
The brackets are OEM for 2012 headlight (sewell sells those too), not specifically made for sewell LED headlight on sale here. and yes, all 3 screws and little tabs on the headlight near the screws line up 100%. I did not want to do the cutting, and bought a used bracket to try out, and turned out to be perfect fit on my 06 bumper
Attachment 244734
thanks Quang, but when I look at sewell website, it has two different brackets type? one for non HID and one for HID, so all I see parts # 51226 and # 51225, but not # 51226-53070?
Old 04-27-12 | 10:16 AM
  #668
quang's Avatar
quang
You search the wrong part# ohiois350, re-check my post
http://is.sewellparts.com/oem-catalo...S350-2012.html
Old 04-27-12 | 10:24 AM
  #669
Joe Z's Avatar
Joe Z
Question
Well we know the new brackets fit and work on the new headlights...
BUT, do the fronts of the "Front Bumper Support" brackets lock into the 2006-2010 bumper tabs and hold the bumper into place correctly ???
Thats the key question..
~ Joe Z
Old 04-30-12 | 01:20 AM
  #670
IceIridium's Avatar
IceIridium
Got my headlights in!
They're just wired the default way for now. Will get in there later and change it to full time DRL. Though still undecided whether I want it to dim with low beams.... hmm....
Old 04-30-12 | 01:28 AM
  #671
Sango's Avatar
Sango
Illegal parking near cross walk....! Need to take that front plate off..!! Somewhere in Vancouver?!
I was just in Richmond this weekend.
Old 04-30-12 | 01:46 AM
  #672
IceIridium's Avatar
IceIridium
What can I say Sango, I'm a rebel.
Naah... too much work. And also I'm so used to the plate on now anyway.
Industrial Park in Burnaby (near the Vancouver border) just off Marine.
Old 04-30-12 | 08:46 AM
  #673
Sango's Avatar
Sango
I thought I recognized the area somewhere but couldn't pin point where. For one thing, the theme of the lamp post didn't quite seem like Vancouver to me while it did resemble other places in BC, such as Burnaby.
Old 04-30-12 | 10:49 PM
  #674
danhtran's Avatar
danhtran
how do i order 2012 headlamps?
on sewell i dont see anything that say 2012 headlamps?
is this 2011 or 2012 http://is.sewellparts.com/accessorie...2010/2400.html
Old 04-30-12 | 11:36 PM
  #675
stasis3131's Avatar
stasis3131
I believe they only send out the updated version now so you should end up with the 2012 pair
Quick Reply: sewell offering 2011+ LED headlights for $1200
