sewell offering 2011+ LED headlights for $1200
Old 02-28-12, 08:48 AM
  #61
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
There just isn't enough room in the headlight with the type of LED setup they were using to also keep the AFS motor in there.
AFS is optional on the 2013 GS, but I assume the lights are designed differently to handle it. Also the GS uses only Bi-Xenon with no halogen high beam, so there is more room in the headlight for other things. The GS350 has rear-mount bulbs and super easy to change ballasts though, so they should have wider output than the IS anyway. Having AFS would be icing on the cake. A few new Toyota/Lexus models are going to the new ballast design (Round ballast behind the bulb. It is the cover you remove to get to the bulb. Very easy to change.)
I have a feeling that AFS will likely get added back to the IS when the 3IS comes out, as they will have a change to design the headlights with enough room for both.
Jeff
Old 02-28-12, 09:39 AM
  #62
jbounnoi
jbounnoi's Avatar
Originally Posted by JoshIS408
are these the DEFECTIVE ones or the new ones after the TSIB? If they are new I wonder how I can get mine replaced? Its been less than a year
me to, i pm'd sewell.. and i bought them when they were around 2500 lol i want a damn replacement
Old 02-28-12, 09:45 AM
  #63
600rr05
600rr05's Avatar
Originally Posted by Legend217
Also can you ask them if stripped set come with relay flasher ?
I called this morning and left a voicemail once they call me back ill let you guys know if they are the 2011 or 2012 lights and if they come with the relay.
Old 02-28-12, 11:33 AM
  #64
NSGxLEX
NSGxLEX's Avatar
I placed an order yesterday and used the extra money I saved for overnight shipping and I just received them 10 minutes ago. Thanks Sewell!
  #65
NSGxLEX
NSGxLEX's Avatar
They came with a relay.
Old 02-28-12, 11:41 AM
  #66
Legend217
Legend217's Avatar
God !!! It's that fast. Let me know how the process go and post some pics once you're done. Good luck
Old 02-28-12, 11:47 AM
  #67
NSGxLEX
NSGxLEX's Avatar
Literally 24hrs
Old 02-28-12, 12:05 PM
  #68
GiantsFan
GiantsFan's Avatar
Those look like the new 2012 headlights with the gloss black surface!
Oh man... WANTTTTT!
Old 02-28-12, 12:40 PM
  #69
fewslowcar
fewslowcar's Avatar
So has anyone figured out how to make auto leveling to work on 2010 IS with AFS disabled? If you just pull the AFS fuse you will loose autoleveling.
Old 02-28-12, 12:42 PM
  #70
Joe Z
Joe Z's Avatar
Received 1,062 Likes on 586 Posts
Lightbulb
Oh man... WANTTTTT!
Sounds right logically.... !!!
The old part numbers that are superseded, usually get PULLED from dealership and warehouse shelves..
~ Joe Z
Old 02-28-12, 12:47 PM
  #71
Joe Z
Joe Z's Avatar
Lightbulb
You leave the fuse in there and watch the AFS OFF light flash...
or
You buy a roll of and crack open the gauge cluster to cover the LED..
It really doesn't get any easier than that...
~ Joe Z
  #72
brociouz
brociouz's Avatar
Originally Posted by 600rr05
i swapped out my bulbs for aftermarket HID's do i still need the fully loaded lights ??
Not sure if you got an answer, but yes.
If you bought yours from Sewell you should be able to return them for the TSIB product within that first year (they certainly won't do the install/reinstall for you though). Hope it works out for you.
LOL, that anxious huh? How much was the extra shipping?
Old 02-28-12, 01:02 PM
  #73
anxiouz
anxiouz's Avatar
Dang, nice deal. So very tempting...
Old 02-28-12, 02:06 PM
  #74
GiantsFan
GiantsFan's Avatar
Does anyone want to donate to the Raj needs 2012 headlights fund?
I accept paypal!
HAHAHA
jk
Old 02-28-12, 02:10 PM
  #75
IceIridium
IceIridium's Avatar
Sorry newb questions...
What's the flasher relay for?
The mod to keep the LEDs on 100% all the time without dimming, is that built in now? Or does that have to be modded?
Quick Reply: sewell offering 2011+ LED headlights for $1200
