9005 DRL led with cree proyector, what you think?
I was browsing on ebay and found this , do you guys think they will be bright enough and will i lost hi beam function? . it says it will fit 08 is250 mine is a 07 but i dont think there is any difference on bulb size . thanks
http://www.ebay.com/itm/2x-9005-HB3-...item20c053622b
If you live in the city, drive on lighted roads, never use your hibeams then you'll be ok. Should you use your hibeams the LED's will provide no useable light.
im mostly in the city i may hit a cr here and there but not much I already have 102 smt led drl but just wondering if this ones will output more light since they have the proyector. thanks
IMO, these would be a downgrade compared to your current LED DRLs. You'll have a single dot of light shooting forward (that won't light up the road much, if at all), instead of having that high beam assembly filled with light as I assume is the case with your current setup. Don't do it.
imo, these would be a downgrade compared to your current led drls. You'll have a single dot of light shooting forward (that won't light up the road much, if at all), instead of having that high beam assembly filled with light as i assume is the case with your current setup. Don't do it.
Buggeroff6
12-30-15 07:17 AM
