Need help Installing DRL LED + DRL decoder
![Talking](https://www.clublexus.com/forums/images/icons/icon10.gif)
I need help installing Xenon White 9005 HB3 LED Daytime Running Light Bulbs + DRL Decoder Kit For Lexus IS250 (http://store.ijdmtoy.com/ProductDeta...e=LED_SKU45_R4)
where can i fit the decoders? does it fit in the headlight housing? or am i suppose to leave the moisture caps off?
any advice? much appreciated.
If you buy the slim one, it fits inside of the housing but if it's big one, you need to leave it outside. I like the big ones. I didn't have good experience with slim ones so I bought big one and no problem at all when I had 08 IS350. I think it was R4 decoder kit. You need to leave moisture cap off. After I ran the wires, I put the moisture cap back on but it will not sit flush because of wires. I just used some electrical tape and clear silicon to seal those area up and I had no problem. Do it where tape and silicon aren't visual lol. Or you can customize moisture cap by drilling small hope for wires and seal it up after. I was lazy to drill hole on the cap lol.
