***Tire Problems, INPUTS PLEASE***
Old 03-06-12, 05:53 PM
2slixx
2slixx's Avatar
Default ***Tire Problems, INPUTS PLEASE***
I was running on BFG Goodrich G-Force 225/40-18 and 255/40-18. I drove long trips on the highways before and had no "Swaying" problems. I just wrapped some Kuhmo Ecstas SLE same size and when I got on the freeway I noticed these "sways" as if the tires were following the groves on the pavement. I thought it was the alignment like I had a positive or negative toe or something but I called the alignment shop and described to them my problem. The mechanic said its probably not an alignment that needs to be done but some tires have that problem due to thread pattern and that cannot be adjusted. Anyone want to chime in on how I can fix this issue? Will an alignment fix this issue? What is the best approach?
Thanks CL I love you guys! NO HOMO!
Old 03-06-12, 05:54 PM
Gville350
Gville350's Avatar
And your tire pressures are?
Old 03-06-12, 05:58 PM
2slixx
2slixx's Avatar
35 all around. =)
VIPG35
VIPG35's Avatar
Yeah check all your air pressures
Old 03-06-12, 05:59 PM
VIPG35
VIPG35's Avatar
Old tires? i had some with weird bumps on them
Old 03-06-12, 06:00 PM
2slixx
2slixx's Avatar
Brand spankin new tires.. my bfg g-forces didnt have this problem but it also had different tread pattern.
Old 03-06-12, 06:01 PM
Individual
Individual's Avatar
Maybe they are directional tires? I read/heard that directional tires have a tendency to follow the grooves on the freeway surface.
Gville350
Gville350's Avatar
I heard some tread patterns just have that problem. Sucks, but there's not much you can do about it...other than buying other tires. BTW, my BFG KDWs don't have that problem.
Old 03-06-12, 06:24 PM
2slixx
2slixx's Avatar
I think they are asymmetrical tires because it said "OUTER" on one side of the tires I remember looking at. I'll double check to see if the shop did it correctly. Hopefully this fixes the issue. =) Thanks guys!
Old 03-06-12, 06:33 PM
Samieee
Samieee's Avatar
I had a 2006 BMW 325 and the tires that came with it did the same thing. I had to constantly fight the steering wheel as the car went over bumps and grooves. It's the way the tire is horribly designed
Old 03-06-12, 07:27 PM
Sango
Sango's Avatar
35 cold or hot pressure?
Ideal would be for long lasting is 36-38 front, and 38-40 rear hot pressure.
05ls430518
04-30-18 07:05 AM
Miagail
11-04-08 07:23 PM
joedaddy1
Hybrid Technology
15
03-09-08 02:27 PM
initiald15
03-05-08 03:02 AM
diamondgs4
Wheels, Tires & Brakes Forum
03-27-03 09:53 AM
Quick Reply: ***Tire Problems, INPUTS PLEASE***
