Doing my first spark plug change since i got my lexus!
i will be attempting my first spark plug change, i know its way different from honda's and toyota's. anything i should be more cautious about?. and should i replace the header seals too?....
Header seals? I dont think you need to remove the headers in order to replace spark plugs. However, you might need to get a new intake manifold gasket if you plan on removing it. Good luck. Tell us how it went.
P.S. Dont forget to use anti-seize compound on the plug threads. Aluminum heads are soft and cross threading them is a big no-no.
4GR-FSE ENGINE CONTROL: IGNITION COIL AND SPARK PLUG: REMOVAL
REMOVE INTAKE AIR SURGE TANK ASSEMBLY
(a) Remove the intake air surge tank See: Intake Manifold\Service and Repair\Removal.
REMOVE IGNITION COIL ASSEMBLY
(a) Disconnect the 6 ignition coil connectors.
(b) Remove the 6 bolts and the 6 ignition coil assemblies.
REMOVE SPARK PLUG
(a) Using a spark plug wrench, remove the 6 spark plugs.
4GR-FSE ENGINE CONTROL: IGNITION COIL AND SPARK PLUG: INSTALLATION
INSTALL SPARK PLUG
(a) Using a spark plug wrench, install the 6 spark plugs.
Torque : 18 Nm (184 kgf-cm, 13 ft-lbf)
INSTALL IGNITION COIL ASSEMBLY
(a) Install the 6 ignition coil assemblies with the 6 bolts.
Torque : 10 Nm (102 kgf-cm, 7 ft-lbf)
(b) Connect the 6 ignition coil connectors.
INSTALL INTAKE AIR SURGE TANK ASSEMBLY
(a) Install the intake air surge tank See: Intake Manifold\Service and Repair\Installation.
REMOVE SPARK PLUG
INSTALL SPARK PLUG
Last edited by jgbackes; 03-07-12 at 08:59 PM. Reason: Added the install instructions.
https://www.clublexus.com/forums/is-...necessity.html
350?
https://www.clublexus.com/forums/is-...g-service.html
Not sure about a 250 but with the 350, no need to remove anything other than the air intake tube and some of the bolts holding a couple wire harnesses in place for easier access. I just did mine this last weekend and I was done in under two hours. Only problem I had was the spark plug socket kept coming off inside the spark plug hole after I torqued them down so I just taped it to the socket extension, problem solved.
ok i went to lexus to pick the intake manifold gasket and they only gave me 2 of em. any one the the part number to the intake manifold just in case its not the right one and i have to go back. the other thing i dont have a torque measurement wrench do i really need one????
SUCCESS!! although it took me 3 n half hrs. i went at a slow pace to make sure i covered everything. put everything back together. i would say the hardest part for me is torquing the plug. first time using a torque wrench hoping i set it right. put everythhing back together started the car, it started for secs than it died. i waited bout 30 secs then started it again and it was up. i took it for a test drive around the block and then on the freeway. no rough idling, seem to pick up better. i believe its the first time since the care was changed, when i viewed the repair log from lexus. the good knews is no malfunction light is "on". the only thing is when i turn the car off i can hear a air sucking noise dont know if thats normal. ill drive it for couple days and see if it goes away. But overall it wasnt hard just time consuming taking all those crap off. Thanks everyone for the help!!!
yea lexus quote me 500 something, so i decided to do it myself. i spent a good 120 dollars sparks plug plus a few tool i didnt have. will be much faster and easier next time. i think they purposely design the car like this so they get all the service.
