Instrument cluster rattle fix
Read it in a post somewhere else - I put it in the gap between the windshield and the dash. It stops the dash from rubbing against the window, and for the instrument cluster rattle, I simply tightened the screws on the cluster, and it doesn't rattle much at all. :3
I have rattles that only occur on cold days. After the car interior warms up, it goes away.
The rattle is coming from above the cluster gauge. When the car is still cold, I can push down on the leather part (the visor-ish part of the cluster). I can hear it when I go over bumps (very little bumps too).
Is the clips and felt fix the solution for this type of rattle?
So would they fix this if my car is out of the 4yr warranty but still under 50K? It's my understanding that there is a TSB for this. Someone posted that Lexus would do a "complimentary" fix. Can someone attest to this? Thanks
There is a TSB for the dash rattle. However, a TSB is not a recall - TSBs are still subject to warranty coverage, and in this case the dash rattle TSB is ONLY covered by the 4 year/50k mile warranty. If you're out of that warranty, you have to pay for the repair yourself out of pocket. And it's a very involved and expensive repair - out of pocket it will cost you $1000+ because they have to remove the entire dashboard and insulate everything then replace it, all of which takes several hours.
I have never heard of a dealership doing a "complimentary" fix for this TSB, because it's so involved. My dealer did a goodwill fix for the windshield molding cracking, but that's because it takes 10 minutes and the parts are ~$100. I won't say it's never happened, but I've never heard of it happening.
That's what I thought. Just to be clear as the title of the thread might be misleading, my rattle is coming from right behind the steering wheel and appears to be the black plastic that surrounds the gauge cluster. Hoping that someone out there has undertaken this DIY job and can offer some suggestions. Thanks!
I stop by ace hardware store today... bought two rubbers insert... insert one in the corner and one 5 inch away.... rattle noise are completely gone. .. I tuck the rubber all the way in.. u can't even tell is there..
Thanks guys! I'll definitely try this rubber fix and report back.
zoli21
10-02-16 01:04 PM
2004, 250, 300, 466e, 5540453050, cluster, dash, fix, hs, instrument, international, lexus, navigation, panel, rattle, repair, warranty
