My IS250 shakes and alignment not helping
03-10-12, 02:08 PM
My car is kinda shaky so I took it in for an alignment and got the car back and its still shaky in the left front it feels like. Any ideas on what it could be....? I am running Vossen CV1 20's with BCR COILS.
03-10-12, 02:11 PM
WHeel are balance correct weight? Bad tires?
03-10-12, 02:19 PM
Need more info, when does it happen? Does it increase shaking with speed. My guess without more info is a bent rim.
03-10-12, 02:30 PM
It happens only above 45-50, tires are great condition. I'll go get them re-balanced Monday and see if that is it.
03-10-12, 04:19 PM
do u have plastic center piece for ur rims? suppose to help ur rims from shaking when going high speed. im guessing thats it.
03-10-12, 07:16 PM
is yours AWD? if it is, it's normal, all of them have this problem when lowered... if not then maybe something else.
03-10-12, 07:28 PM
Quote:
Originally Posted by
JMcDonald
i'll go with this one first...
03-10-12, 07:58 PM
03-10-12, 08:58 PM
yes hub rings, plastic rings that goes inside the center hub. all aftermarket rims, should recommend getting a set.
03-10-12, 09:26 PM
Hub rings not need if your hub is centric on the wheel. My Weds dont need them as it sit rite on the hub with out movement.
03-10-12, 11:48 PM
roll on your stocks. do a 50/50. but like all.. if u don't got hub rings and your wheels are not hub centric. then that might be your problem.
03-11-12, 05:15 AM
I'm fixing to go check the balance on the wheels, if they check out good then ill go pick up a set of hub rings and hopefully that helps. It's not a bad shake but I can feel it, and my wife drives it to work so she's freakin out lol. Thanks guys for the replies
metalgear
06-19-12 12:49 PM
SMigone
01-18-12 11:29 AM
decibel
03-09-09 01:23 PM
LiqrSicc
RX - 1st Gen (1999-2003)
08-17-06 10:04 PM
D-MAN63
02-16-02 11:02 AM
