lexus is350 spark plug change outcome
just wondering what was the outcome when the 350 people here change their spark plugs, what you guys notice if better MPG, smoother acceleration or anything else
I waited till 79,900 to change mine and that was way to late, I had been dealing with some weird idle and sluggish performance for awhile. I bought my car with 59,000 and it runs better then it did when I bought it. Next up is rear end fluid and brake job...
I changed mine out right after 50,000 miles and noticed no difference at all. Acceleration, performance, idling, it was all the same. I thought my fuel economy became better but it was just because the weather was becoming warmer and there was less traffic where I've been driving.
I understand where you're coming from, which is why people like CAI for intakes. I'm sure a car performs better in temps around the 60's rather than 90's or 30's.
You're over-thinking this lol. The engine revs higher on cold starts and it takes longer to warm up to operating temperature. It wastes more gas like that. That was like in 40 degree weather. Then it got warm to past 60 and it only took under a minute of driving to warm up unlike normally when it takes 5-10 minutes. Not to mention, maybe gas stations also changed their blends since the seasons were changing.
No. The colder the air the denser it gets. That translates to more fuel that is injected into the combustion chamber to reach pre-determined ratio. Therefore, you'll get better performance not better MPG.
Hey,
Ive changed my spark plugs and wanted to get your opinion on whether the sparks show any bad signs of wear on the engine running.
Im currently at the 100km or 60k miles mark.
I had also torqued my spark plugs to 20ft cause the torque wrench lowest setting I had available was 20ft lb. The recommended setting was 18 from the dealer is it fine even to be a bit over?
carrwash13
12-12-11 11:42 AM
