Help! Passgenger Headlight wont turn on.
So today i was switching my aftermarket hid bulbs from 6k to 5k and everything went swell. The lights to my liking had a very nice color to them in contrast to the 6k that was more of a ugly aqua color. well after i dazed into the light for a few seconds in admiration i shut them off and began to put everything back in place. when i was done and went to move the car the passenger side headlight wouldnt turn on anymore. I tried to put back the old bulbs to see if it was the new bulb that failed but no luck. I switched the ballast out for an extra ballast i had and still no luck. Finally i disconnected the kit and tried the oem halogen bulb and still it would not turn on. I doubt it would be the fuse because the driver side light still works fine. Anyone can help me?
I would still check the fuse. but sounds like a electrical problem. my passenger died on me once but it turned out the connecter for the ballast was just loose. Did u do a recheck on wires connectors etc??
