is350 cluster problem
Old 03-16-12, 08:39 PM
uhhuh350
uhhuh350's Avatar
Default is350 cluster problem
Has anyone experience this problem? is it just a led bulb i can change out?
Both needle has that problem but the rpm needle is lighter
i did a search but can't find anything on that. Sorry I'm new at this
Old 03-16-12, 08:43 PM
Deathrow23
Deathrow23's Avatar
yes, i have this same issue also on both, sometimes it flickers and lights back up...07' 62k miles
Old 03-16-12, 08:48 PM
Shervin350
Shervin350's Avatar
cluster needs to be change completely, you can change the light your self but it aint easy i say just dont about it
uhhuh350
uhhuh350's Avatar
yeah mine stay like that, doesn't flickers
Old 03-16-12, 08:50 PM
Herofmine
Herofmine's Avatar
You can get from junkyard or ebay. And forget about the problem))
Old 03-16-12, 08:51 PM
Hoovey689
Hoovey689's Avatar
you see this on older SC's a lot
Old 03-16-12, 09:26 PM
speedstar
speedstar's Avatar
Mine has that same problem
Old 03-16-12, 09:33 PM
Denver
Denver's Avatar
there is a diy thread on how to fix it
Old 03-16-12, 09:46 PM
chi123
chi123's Avatar
I made a crappy DIY on it almost a year ago how how to change out the LED bulbs in the needles. Basically, there are 4 LEDs in the needles. One of them burnt out on each of your needles. You'll either have to buy a new cluster or change out the LEDs yourself but that requires soldering skills. I can fix them and also do any custom cluster work for $50 flat. Message me if interested. I just finished another member's cluster two days ago.
https://www.clublexus.com/forums/is-...g-needles.html
My cluster:
Old 05-14-12, 06:31 PM
MiiK350
MiiK350's Avatar
Anyone know if this problem is covered under warranty?
Old 05-14-12, 06:37 PM
laobo979
laobo979's Avatar
If your under factory warranty I'm sure it is.Cause factory warranty is bumper to bumper.
Old 05-14-12, 06:39 PM
chris07is
chris07is's Avatar
guys... mine died along time ago, i got used to it already Im out of warranty already...especially the speedometer..i can only recognize it when ago above 75mph...
Old 05-14-12, 07:14 PM
MiiK350
MiiK350's Avatar
I should have specified that I'm under CPO warranty only now. Apologies...
Old 05-15-12, 06:11 AM
Kurtz
Kurtz's Avatar
I'd certainly expect that to be covered by CPO
Old 05-15-12, 09:38 AM
Kahdoe
Kahdoe's Avatar
I've had this problem and the dealership replaced the cluster at no chrage due to warranty.
Quick Reply: is350 cluster problem
