IS250 Engine Noise
Old 03-17-12, 12:04 PM
diljay
diljay's Avatar
Default IS250 Engine Noise
2007 IS250
Mileage: 79XXX
Auto
Hey guys,
I've been noticing some knocking/tapping noise coming from the engine. This is definitely the sound coming from the direct injection. Do you think this is the dreaded piston slap noise? I've searched for threads regarding this issue but haven't found anything specific to the is250. Any help would be greatly appreciated.
Old 03-17-12, 12:13 PM
Gryss
Gryss's Avatar
Originally Posted by diljay
2007 IS250
Mileage: 79XXX
Auto
Hey guys,
http://www.youtube.com/watch?v=td8252neMiM
bad noise, bad noise, bad noise.
Where in CA are you located?
I work at a Lexus dealer in the service department. If you are close enough I will get it looked at for you. But from the clip, it sounds serious.
Old 03-17-12, 02:10 PM
Denver
Denver's Avatar
dang, what did you do to your IS? that knocking sound is bad, you're going to need to rip that engine apart to see whats the damage
Old 03-17-12, 03:40 PM
feng
feng's Avatar
Probably a long shot but maybe it's the water pump. My car had a sound similar to that. Mine sounded like a dirty bearing and the sound would go away when I revved the engine but come back on lower rpms.
Old 03-17-12, 04:25 PM
Boostd
Boostd's Avatar
I had this sound in my Maxima turned out to be a bearing going out in the alternator.
Old 03-17-12, 05:23 PM
diljay
diljay's Avatar
Hello Gryss,
Thanks for the quick response. I live in San Francisco and commute to Palo Alto during the week. How much does the dealership usually charge for a diagnosis?
I'm planning on removing the engine covers and pin pointing whether it is in fact bad bearings in the water pump, alternator, or power steering. It's been raining so I'm not sure if I'll get to it this week. I'll let you guys know if I find anything out.
Old 03-17-12, 07:35 PM
RTIS250
Yes. I drove the LFA.
RTIS250's Avatar
20 bucks says its a bad water pump... heard it before.
Old 03-17-12, 09:51 PM
diljay
diljay's Avatar
Man i hope it's not the water pump. I don't have time to replace it myself nor do I have an extra car at the moment. The last thing I would want is the water pump to seize. Does anyone know if the 4grsfe is a non interference motor?
Old 03-17-12, 10:22 PM
RTIS250
RTIS250's Avatar
The water pump is driven by the drive belt, so if it seizes, the drive belt will likely break, but has nothing to do with being an interference engine or not. Its not an old timing belt engine that will cause a broken timing belt, these engines are chain driven. But if it seizes, its gunna overheat...
Old 04-13-12, 06:59 AM
Touge
Touge's Avatar
Any updates on this ?. I noticed a similar sound on my is250.
If it was the water pump, would it be covered under the powertrain warranty ?
Old 04-13-12, 08:04 AM
juvi22003
juvi22003's Avatar
I heard that same noise in my engine its at the dealership now, not so good when it comes to engine problems, could be cam gears....
Old 04-13-12, 11:41 AM
JETLEX
JETLEX's Avatar
I had a very similar sound in mine that turned out to be the H2O pump.
Yes, it was covered under the power train warranty - no charge to me.
Old 04-15-12, 06:33 PM
Touge
Touge's Avatar
Thanks for the heads up. I have my appt tomorrow for the water pump.
I also heard a squealing noise from the engine bay today, at idle not that strong, but as you build up rpms 2-4k you can hear it. Wonder if that is related to the pump.
Old 09-06-12, 07:14 PM
polishpete
polishpete's Avatar
so what happen??
was it your waterpump making that noise after-all?
i have a similar noise in mine at 68,000 km
It is covered by warranty though.
Old 09-07-12, 03:37 AM
DaveXIX
DaveXIX's Avatar
Been here before. I'll up the bet. I'll put $100 saying that it is the water pump. After I had that fixed it ran as smooth as a fresh baby *** lol
Quick Reply: IS250 Engine Noise
