turn signaling does not turn off
Old 03-18-12, 03:00 PM
08lexus350
08lexus350's Avatar
Default turn signaling does not turn off
hello people/friends, i have a 08 is350 and my turn signals don't turn off automatically after completing a turn, any ideas what it can be? thanks a lot
Old 03-18-12, 03:07 PM
iRock
iRock's Avatar
Nope I always switch mine off myself. If I use them
Old 03-18-12, 03:15 PM
08lexus350
08lexus350's Avatar
i can't do that, no ways its too annoying to do it manually, but what can be wrong that it doesn't turn off automatically
Old 03-18-12, 06:55 PM
Gville350
Gville350's Avatar
Time for a new combo-switch.
Old 03-18-12, 08:19 PM
08lexus350
08lexus350's Avatar
really? weird
Old 03-18-12, 10:35 PM
KillaIS250
KillaIS250's Avatar
You don't happen to still be under warranty do you? lol
Old 03-18-12, 10:37 PM
Denver
Denver's Avatar
possibly the switch
Old 03-19-12, 06:21 AM
08lexus350
08lexus350's Avatar
no warranty
Old 03-19-12, 07:50 AM
brociouz
brociouz's Avatar
Most likely a mechanical failure. Either buy a replacement part or ignore/deal with it, unfortunately.
Old 03-19-12, 11:50 AM
08lexus350
08lexus350's Avatar
so it would be this combo switch unit?
Old 04-26-12, 10:43 AM
08lexus350
08lexus350's Avatar
hey guy i changed my combo switch unit and the turn signal flasher and still the same problem?? the turn signaling still blinks fast and doesn't turn off on its own after completing the turn, all bulbs are working, front back turn signals are good, ??? any idea what it can be now since i eliminated some things
thanks a lot
Old 04-26-12, 11:29 AM
GiantsFan
GiantsFan's Avatar
Blinking fast usually means a bulb is out... (or if you have LEDs and haven't changed/modified your flasher).
Maybe it's your flasher unit???
Old 04-26-12, 02:04 PM
08lexus350
08lexus350's Avatar
no bulb is out though, whats and where is the flasher unit?
Old 04-26-12, 04:26 PM
Sango
Sango's Avatar
The flasher unit is somewhere behind the dashboard where the instrument cluster is.
You need to remove the kick panel where the gas/brake pedals are which is held by two screws. Move the kick panel to the side, then you're going to have to lie down on your pack with your head down on the floor hear the panels and use your hands to reach up to the turn signal flasher which is secured to a metal like post.
RBnSD
RBnSD's Avatar
Check this out, might help:
https://www.clublexus.com/forums/gs-...flash-fix.html
Quick Reply: turn signaling does not turn off
