Couple pictures of my car.
Old 03-27-12, 12:44 AM
  #31
LostS0ck
LostS0ck's Avatar
Offset is +20 all around, Thxs guys.
Old 03-27-12, 04:15 AM
  #32
steezy
steezy's Avatar
Looks good. But question, what are you trying to go for? tuner or vip? reason for asking, cause of the knots with the wheel setup you have. and majority here in hawaii go for the vip over tuner
Old 03-27-12, 09:10 AM
  #33
dorkacho
dorkacho's Avatar
very clean looking
Old 04-01-12, 09:14 PM
  #34
jsigone
jsigone's Avatar
looks pretty good. Any rubbing?
Old 04-01-12, 11:36 PM
  #35
try2fndmrk
try2fndmrk's Avatar
Wow, those XXR's looks pretty damn good
Old 04-02-12, 09:44 AM
  #36
vtxmask
vtxmask's Avatar
Looks really nice. What's the alignment? I just got 18x8.5's with +35 because I didn't want to do fender rolling. If the camber was 0% i woulda had a flush fitment but the mechanic suggested -2% which puts the wheels in a bit at the top, Maybe you can avoid the rub if you get -2% but to compensate for the inside tire wear, he adjusted the toe to point in slightly at the front of the wheels so the wear turn out to be fairly even.
*first post on this website
Old 04-02-12, 12:38 PM
  #37
ASPLS430
ASPLS430's Avatar
How do you not rub? Im running 18x9.5 +20 all the way around on stock tires too and Im rubbing everywhere. I cut the tabs and shaved the fenders and still rub. Im not even lowered yet haha
Old 04-02-12, 01:03 PM
  #38
tp350
tp350's Avatar
Looks good! I almost got those.
ASPLS430- It's all about working the fenders, liners tabs etc. I am running 18x9.5 F and18X10.5 R +22 I only rub in the rear on one side if I hit a good sized dip at speed. I shaved the front tabs, heated liner back, rolled and pulled fenders, and shaved rear tabs. I am dropped on megan ez and amd running 224/40 up front and 255/40 in the rear. Where are you rubbing? With no drop, you also have no negative camber which may be causing some issues depending on where you are rubbing but I dont see that being an issue unless you hit a huge dip.
Old 04-02-12, 01:09 PM
  #39
Haitwun
Haitwun's Avatar
I adore the yellow brake calibers. Nice job.
Old 09-05-12, 04:25 PM
  #40
reyoasian
reyoasian's Avatar
Is your car AWD or RWD?
What size tires? 225/40R18 front...and 255/40R18 rears?
I have 2009 IS250 AWD on H&R.....deciding whether to go 8.75 all around or stagger....and after seeing your post, definitely going for +35 instead haha
Old 09-05-12, 05:18 PM
  #41
skullkandy
skullkandy's Avatar
is this chromium black or woteva its called?
Old 09-05-12, 07:48 PM
  #42
bboysunone
bboysunone's Avatar
Looks good!! Drop alittle lower. And add a front lip kit it will look sick *** Hell
Old 09-05-12, 08:16 PM
  #43
RDIS250AWD
RDIS250AWD's Avatar
those wheels remind me of the Bavaria BC10's
Old 09-05-12, 08:33 PM
  #44
neilr11
neilr11's Avatar
Nice, I need to get some drop springs.
Old 09-05-12, 08:39 PM
  #45
Hoac
Hoac's Avatar
Nice ride bud !
Quick Reply: Couple pictures of my car.
