is this the AFS?
Old 08-07-13, 10:34 AM
  #31
carlosL250
carlosL250's Avatar
My AFS Off is blinking on and off, and this happened after I got towed. Is it likely that the towing company is the culprit and broke my sensors?
Old 08-08-13, 05:57 AM
  #32
RoyLPita
RoyLPita's Avatar
Arrow I'm new here to respond to old threads......:D
Originally Posted by rebs
I have an interesting problem.
I noticed my lights were a little off, and the afs off light flickered once, so (after reading the forums) I took a look at my front height control. It looks like the nut/bolt attached to the ball bearing (for lack of a better description) broke off the level arm, so it's no longer attached (to the sway bar?). I looked at Sewell and it looks like you have to buy the entire sensor assembly for $300 just because the bolt/nut broke off the arm. Is that correct? Seems a little crazy.
http://is.sewellparts.com/oem-catalo...S350-2008.html
Any alternatives? I notice the leveling arm has the following part number thk-bw60a-0530. I couldn't find that anywhere, and I also didn't have any luck at junk yards.
I could use some advice.
Try here:
www.car-part.com
www.junkyarddog.com
Look for those that have HID headlamps for your year IS then ask if they have the car with the sensors.
Old 08-09-13, 02:51 PM
  #33
Adamm
Adamm's Avatar
Originally Posted by brociouz
I've never adjusted my headlights using the screws up front, but remember reading it's somewhat complicated by the fact that there are 2 screws for each headlight and they have to be adjusted together in order to get the lightsjust right. Is that not accurate?
There is only one adjusting screw per headlight just count the amount of times you turn one and then repeat on the other adjusting screw simple and done.
Old 08-10-13, 09:08 AM
  #34
pwr2loud4u
pwr2loud4u's Avatar
Originally Posted by jgbackes
My understanding is there are two different systems here. One is headlight leveling which moved the lights up and down. The other is AFS, that moves the lights to the right and left.
If you have the rear of the car fully loaded the leveling system will insure that the lights do not blind oncoming drivers. If you have AFS, the lights will turn to the right and left with the speed of the vehicle and the angle of the steering wheel.
The parts you show are from the leveling system.
Hope that helps.
jeff
Where do you get all your spec pics?
Old 08-31-13, 08:50 PM
  #35
Skyfox16
Skyfox16's Avatar
So after reading these posts I'm still a little confused....
I have an 06 with AFS and it seems my headlights are a little lower than i would like and i wanted to raise them a tiny bit.
Am i able to just use the screw driver adjustment method at the headlights themselves OR do i have to only adjust the rear AFS sensor?
Old 09-01-13, 01:27 PM
  #36
clubfoot
clubfoot's Avatar
If you want to adjust both evenly, especially if you've lowered your car, use the AFS adjustment on the left rear suspension of your car. Otherwise you will have to use both screws on each head light to keep them straight.
Old 11-16-13, 11:03 AM
  #37
Dimaggft
Dimaggft's Avatar
Default Repair Lexus
48906-35020. - this is part is from prado(. Toyota) it will help you too repair you is 250
bmaez
11-02-11 07:41 PM
bennyc
10-06-10 11:26 PM
cowlemon
08-19-10 10:26 AM
posdriftin
02-20-08 06:21 PM
Quick Reply: is this the AFS?
