OEM Brake Pads
Old 03-20-12, 01:58 PM
ISF350
ISF350's Avatar
Default OEM Brake Pads
Hi guys,
I need to do a front brake job and replace my front brake pad for 09 IS350. Could you let me know where I can order 1 set of OEM pad for good price. I called longo lexus and they said $85/pair plus tax so it about $95 otd. Also, is there any thing I need to do for the front brake job or just a brake pad ? It will be the first brake job for the front.
Thanks
Old 03-20-12, 03:59 PM
Gville350
Gville350's Avatar
People recommend a new shim kit along with the pads. Order from Sewell; they offer a CL discount!
Old 03-20-12, 04:00 PM
thebossac
thebossac's Avatar
you can contact kerry at Lexus of Westminster, they are having a March Madness Sale, see link below.
https://www.clublexus.com/forums/clu...cessories.html
Old 03-20-12, 04:11 PM
kingster
kingster's Avatar
Get a price quote and if Lexus Westminster is too far for you, I'll recomend calling your local Lexus Dealers and ask if they would match their competitor's price/s. I have done that at El Monte Lexus. Chris Cucuta has given me really good prices. I get the parts I need on the spot and not wait for days to be delivered.
Old 03-20-12, 04:32 PM
anthrax144
anthrax144's Avatar
Go to Sewell. Register as a CL member. Front pads are $46.84 after discount plus about $10 shipping (maybe cheaper as you're in CA.) http://is.sewellparts.com/accessorie...2009/1886.html
You can re-use the shims already on the car, just clean them with brake cleaner and apply some new grease to them. Once installed be sure to be in the brakes: http://www.zeckhausen.com/bedding_in_brakes.htm
Old 03-20-12, 06:58 PM
ISF350
ISF350's Avatar
Thanks guys.
There are 2 different model pads. The best price locally is the older pads cost around $56/set and the new improved dustless pads cost $80/set at Lex of westminster. I will pick up the dustless pads tomorrow and get ready to install by this wkend
Old 03-20-12, 07:15 PM
juvi22003
juvi22003's Avatar
order front sewell and a new shim kit.....i just order new pads from them and stoptech rotors. changed my shim kit about 6 months ago so i didnt bother to get new ones this time around.
SolidG1
GS F (2016-present)
03-16-19 07:10 AM
myspec15
IS F (2008-2014)
02-29-16 09:56 AM
radicalrev
Maintenance
20
05-14-08 07:49 PM
Quick Reply: OEM Brake Pads
