stock 18 rims" with 30mm spacer .
Old 03-22-12, 06:22 PM
350250's Avatar
Default stock 18 rims" with 30mm spacer .
test fit rear are perfect front stick out tires to wide for front rims
Attached Thumbnails stock 18 rims" with 30mm spacer .-img_0161.jpg   stock 18 rims" with 30mm spacer .-img_0156.jpg   stock 18 rims" with 30mm spacer .-img_0155.jpg   stock 18 rims" with 30mm spacer .-img_0153.jpg   stock 18 rims" with 30mm spacer .-img_0158.jpg
Old 03-22-12, 07:00 PM
heyarms
heyarms's Avatar
Is a 30mm spacer at all safe to be running?? either way my opinion of spacers are still
Old 03-22-12, 07:01 PM
MashinA
MashinA's Avatar
Looks good now drop that bish
Old 03-22-12, 07:25 PM
tBayBoi20
tBayBoi20's Avatar
looks nasty from the back...Mmm
Old 03-22-12, 07:27 PM
robertrios
robertrios's Avatar
lol damn i just sold mine, im on isf 19x9 though so it probably wouldnt have worked. im running 38mm spacers on the 430
Old 03-23-12, 12:20 AM
KillaIS250
KillaIS250's Avatar
Damn your brave, I wouldn't ever run a spacer, yet alone a 30mm
It does look much better though then stock
Old 03-23-12, 06:46 AM
obby
obby's Avatar
will look allot better if lower.
Old 03-23-12, 07:08 AM
prankster
prankster's Avatar
IMO, do it right. Don't use spacers. Get yourself a set of wheels with the right offset.
You can do yourself a favor by doing a search on Ichiba spacers. See what fellow CL members had experienced with those spacers.
Otherwise, go stock style.
Old 03-23-12, 08:05 AM
iRock
iRock's Avatar
Risky
Looks better though
Old 03-23-12, 09:36 AM
iTaLiAnO
iTaLiAnO's Avatar
is that 30mm front and back? and ur not rubbing?
Old 03-23-12, 10:16 AM
Vroomin350
Vroomin350's Avatar
the spacer issue will always have two advocates. Many people run spacers with ZERO issues, I've seen SC's running 40mm. It's all luck of the draw, and ofcourse knowing how to PROPERLY install them.
Old 03-23-12, 02:36 PM
juvi22003
juvi22003's Avatar
Dont think i will ever be a fan of spacers.....
Old 03-24-12, 01:20 PM
350250's Avatar
yeah i gambled with 30mm front rubs a little bit only use them for a day so no worries there were fine no vibration or nothing need some wide rims lol thinking bout privat akzent
Old 03-24-12, 02:08 PM
jgarrido
jgarrido's Avatar
look good!!!
grekt
05-16-17 07:26 PM
Nasrul3698
06-24-16 10:37 PM
iTaLiAnO
Suspension and Brakes
03-17-12 10:48 AM
peterwho
02-11-11 04:54 AM
hurricane
05-18-08 12:53 PM
Quick Reply: stock 18 rims" with 30mm spacer .
