warning! jmdtoy drl
#46
Okay, thanks again for shipping the slim ones. I completely understand how the mishap happened. Ijdmtoy definitely has good customer service if you just talk to them and let them know the situation. I'm looking forward to getting these installed!
#52
OK.... so I just got mine a couple of days ago and I agree with this guy. Had the same issue. After I investigated, I noticed that the clip was not manufactured the right way. iJDM sent them out having the clip reversed... so I de-pinned them and switched it around so that it would clip on correctly. Also, the body of the LED broke off while I installing it, hot glue and re-soldered it back together. Then... the light still had a slight flicker...WTF!! I had to basically rebuild this freaking kit.
So I went up to Radio Shack and got 2 new capacitors, solder those back in, and now no more flicker....
THEN... I find out that the decoder is too big to tuck inside the headlight housing, so I stripped it down to fit in there....
OVERALL experience with this LED kit, and the company... TERRIBLE!!!
NO CONTACT BY PHONE, VERY SLOW EMAIL CONTACT, NO RESOLUTION, NEVER AGAIN!!!
I tried contacting you plenty of times dude... there is no phone number to call for assistance and you hardly email back...
#53
Former Sponsor
The slim decoders are only available via me over PM's or via email. Please contact me first before ordering if you want the slim decoders.
#56
This is what I did... you have to make sure the red line from the car matches the red line on the decoder. Even if the clip does not look right.
If that is correct, you may have blown a fuse...
The location of the fuse is in the the engine bay fuse box on the drivers side. Look in the box and look thru all your blue 15 amp micro fuses. One of those are probably popped. I can't remember specifically which one it was so just go thru them one by one...
I didn't get a refund but got a resolution insead..... it works for me![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
Hope that helps
Hope that helps
#60
Hope that helps
Hope that helps
