QUESTION on FITMENT. I could search...
![Talking](https://www.clublexus.com/forums/images/icons/icon10.gif)
So I'm thinking of going the affordable route, taking everything into considering I have a 2006 IS250, has 104,000+ miles on it.
Ive contacted Varrstoen and they offer the ES 1.1.1 in 19x9.5 and 19x11, would that work? Asking all the wheel pros in this forum.
suspension: WILL BE, Megan EZ street coils, gonna order next week.
you could have used the search function and at least find the "Will those wheels fit? Start here." thread.
i can tell you how you can make it work, but i've already told others what needs to be done in that thread, so it's already been addressed.
you just need to search for it.
Am I reading the size chart wrong cause the 1.1.1 only come in 18's? The 1.1.2 come in 19's and the offsets for 19x9.5 are 0,12,22,30. The 19x11 are 0,15,25,30
Size chart: http://varrstoen.com/VARRSTOEN_SIZE_CHART_v5.1.pdf
the offset AND width of the wheel, is.
maybe the OP does mean 1.1.2.
![](http://i10.photobucket.com/albums/a129/killakorean/473ee227.jpg)
Reason for 19s, i have a pair of 245/35/19, Michelin Pilot Sport 2, i don't wanna let them go to waste.
so the question, after looking at their sizing chart, what would be the "best" setup to go with considering i will get the coils and lower approx 2 inches.
maybe a "semi-aggressive" look, if that makes sense.
so much info out there to fish through. lol.
It's going to be hard to fit those. I am running 9.5 F and 10.5 rear +22 and I have rolled and pulled fenders, shaved parts of fender tab in the rear, relocated tabs front, and remolded fender liner in the front. After all that I don't rub anymore. I am still going to go with a 245 in the rear and get Megan camber arms and figs toe links so that it will be ok in the rear when i have people riding with me. I also may want to drop it a little more.You have to know what your getting in to. It's worth it if you want the look but you have to pay to play so to speak.
P.S.- I am on Megan Ez's running full stiff all the way around. If you want to go really low(tucking tire), you may want a stiffer spring rate than what the ez's come with.
