Code help on is350
Code help on is350
hey guys took my car to the dealership and they gave me 4 codes that came up, C103, C1241, C1336, and C0278,
- i searched them and found that the C1241 code could be for
1. abs hydraulic pressure differential switch input short circuit to ground
2. low battery positive voltage
the code C0278 - is for Open or short circuit in the abs solenoid relay circuit.,
-the other two codes i can't figure out, i was wondering if anyone knows anything about how i can fix this myself before the dealership robs me,,.
thanks a lot ahead for help.
They did not recommend any sort or repair?
BRAKE CONTROL: VEHICLE STABILITY CONTROL SYSTEM (w/o VDIM): C1210/36,C1336/39: Zero Point Calibration of Yaw Rate Sensor Undone (2008 IS250 IS350)
BRAKE CONTROL: VEHICLE STABILITY CONTROL SYSTEM (w/o VDIM): C1241/41: Low Battery Positive Voltage (2008 IS250 IS350)
BRAKE CONTROL: VEHICLE STABILITY CONTROL SYSTEM (w/o VDIM): C0278/11,C0279/12: Open in ABS Solenoid Relay Circuit (2008 IS250 IS350)
Found nothing for c103
Tha is really strange!!
How is it that dealership tech. pulls out all these codes but nobody takes the time to explain what each means. NOt a dealership I want to go to.
If I were you, I would call them and demand an explanation for each of the codes. Hopefuly, you are under warranty and they can take care of all these issues.
good luck
good luck
Yes is an 08 is350, not under warranty anymore, they charging me 120 for the computer that they hooked up to it and said he'll need about another 3 hours to tell me whats wrong, and their hourly charge rate is 119, but they told me they do it 90$/hr. which pisses me off ill be paying close to 400-500$ just for them to tell me whats wrong.
what is this LOW BATTERY POSITIVE VOLTAGE ?
- I just want to figure some things out on my own so when i come in i want to know where 3 or so hours of there time went into.
I have never once heard of a dealership charging an hour's labor to simply hook up an OBD II scanner to a car and pull codes. That's not an hour's labor - that's 2 minutes' labor.
I can tell you that anytime I've brought my car in with a problem, they've charged me an hour's labor to diagnose it. No more. I've never heard of a dealership saying it'll be 4 hours labor just to tell you what's wrong. Particularly when all the codes are related and appear to be related to the VSC.
Go to another dealership.
your battery is low?? replace battery first. low voltage can make other components not working properly because they are not getting the correct voltage
did they charge you a diagonsic or just to check the code?
