how to turn on ijdmdrl led lights?
im in a pickle, i just install them but the drl are not turning on, i thought buying these will eliminate the ugly yellow parking lights..... i need help
if you installed it properly, it would turn on just like your factory 9005 use to turn on. doesnt require any new way to turn it on.
turn your car on. leave in park.. take the parking brake off. they should turn on. or u can flash your high beams to test since its the same bulb.
parking lights and DRL is two separate bulbs. your ugly yellow parking light is a 194 Wedge Bulb located towards the top corner of the highbeam/DRL area.
so what i change was my drl right? my parking light is only when im park and doesnt /shouldn't be on when im driving right ??
i guess ill start my car and still wassup tommrow
