Got a alignment today. Am I within factory specs?
Finally got a chance to get another alignment for uneven inner tire wear. Could someone help me interpret these results?
I am lowered to about 0 finger gaps all around.
Looks like the red items are just outside of the normal range and that would be expected when your lowered.
Just had mine done I am on F-Sport Springs/Shocks (I assume you are lower) and I came in at : -1.4 Left-F / -1.3 Right-F / -1.6 Left-R / -1.8 Right-R (camber).
The front TOE looks about the same as mine although your rear toe is higher - mine is .05 yours being .16 although still within spec. If it is within spec I don't see any need to be concerned.
My rear doesn't wear out as fast as my fronts though. I can easily get 30k on rear but fronts I can only get about 20k.
The insides of your front tires are wearing faster than the rest of the tread, am I right? I think many of us (especially with lowered rides) have a similar problem. So far I've been mitigating the problem by having the tires unmounted and remounted left-to-right every few thousand miles, but I'm planning on getting an alignment done by a performance tuning shop who knows what they're doing rather than a monkey shop that just follows the specs that they read out of their book.
I've read that all we really need is a bit more toe in on the front wheels. On RWD cars, you need a bit more toe in than on FWD cars. Since the front wheels are being pushed by the rear wheels, they have a tendency to rotate around the kingpins towards the back of the car, causing some excessive toe out at speed, which then causes feathering and extra wear on the inside of the tire. Apparently this car does not have enough toe in from the factory, and the problem is exacerbated by lowering the car. Unlike what many people tell you, it is NOT a camber issue.
That's my understanding, at least. And I intend to find out soon enough if that's true.
