HELP-Grom Audio install
The bottom left bolt on my radio panel is completely stuck. Ive tried everything and cant get it to move. Is there any other way to get to the back of the radio panel? Can I take the dash apart to get back there? Any suggestions are welcome. Thanks guys!
I had a lot of problem with that same 10mm bolt too. It felt like it was stuck when I used a power tool. I end up using something like the pic attached, but with an end you can attach different size bits at the end to fit into the bolt; don't know what they're called not that familiar with tools. I was able to loosen the bolt with it. Hopefully you had gone to the gym lately, or find someone on the heavy side to use their body weight ...
You shouldn't take the dash apart, that's probably a lot of work, and I don't think you can get to it from the top
durtysc300
SC- 1st Gen (1992-2000)
01-19-09 12:40 PM
