Anyone know how much A/C refrigerant the 2IS uses?
Old 04-13-12, 07:12 PM
chi123
chi123's Avatar
Default Anyone know how much A/C refrigerant the 2IS uses?
My car was at the shop getting the frame repaired and apparently the mechanic drained my refrigerant so my A/C didn't work. Today, I bought one of those DIY kits to refill the A/C and now it works fine but I only used one can. Anyone know how much refrigerant is needed to make the system full?
Old 04-14-12, 11:02 AM
Gville350
Gville350's Avatar
Well, most of those DIY kits now come with a dial/gauge with the can that show when you are at the optimal level/pressure. Did you not get one of those I guess?
Old 04-14-12, 12:12 PM
ISBU
ISBU's Avatar
Look under your hood, its a yellow sticker.
Old 04-14-12, 12:44 PM
GS4_Fiend
GS4_Fiend's Avatar
This is correct. Its also a good idea to do a vacuum evacuation before adding the freon.
Old 04-14-12, 02:18 PM
Denver
Denver's Avatar
yeah theres a sticker somewhere telling you how many lbs it holds. you dont want to have too much or too less
Old 04-14-12, 02:29 PM
carlos3366
carlos3366's Avatar
Shouldn't your mechanic be responsible to fix it?
Old 04-14-12, 02:43 PM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
400 - 460g (14.1 - 16.2 oz.)
Jeff
Old 04-14-12, 10:03 PM
chi123
chi123's Avatar
^ Uh oh, I couldn't find out in time. Everyone was telling me anywhere from 2-3.5 pounds is the average car. I went to Autozone and bought an 18 oz can and refilled the A/C. It had like 5 PSI left before I filled it. The compressor wasn't coming on either.
The gauges were on there but the problem was that my dumb self didn't think and went ahead to put the refrigerant in right after I got home from Autozone. As I was waiting, I was trying to figure out what was meant by "ambient" temperature since the outside air was like around 60 but the engine bay and my garage warmed up and the bay was like 100. So I didn't know which reading to go with but after one can, I got 45 PSI. I guess I overfilled just by the slightest bit. Should I be concerned that I'm about 3-4 oz over?
And I'll eventually vacuum it out for 30 minutes in the summer time when I get the chance and refill it to the correct amount.
trujtru (07-10-21)
Old 04-14-12, 11:07 PM
allst4r
allst4r's Avatar
you need the right amount or the ac wont get as cold..
if you have too much or too little... at-least that is my impression.
Old 04-15-12, 05:08 AM
ibidu1
ibidu1's Avatar
Too little the compressor wouldnt click on, too much the freon lines freeze up. One big can should do the trick, is the ac ice cold? If not add a little more or take it to a shop to measure and top off if needed
Old 04-15-12, 05:42 AM
Gregz_IS
Gregz_IS's Avatar
Hopefully there wasnt sealer in the can of r-134 or you will be replacing the entire system.
AC is not something that DIY should be messing with.
Trying to save a few $$ can cost $$$$$$$$$$$
Old 04-15-12, 06:09 PM
chi123
chi123's Avatar
A/C is working fine now. Air is pretty cold.
And the can didn't have sealer in it. It was just some "synthetic" refrigerant with some oil in it.
Old 04-15-12, 07:07 PM
XSV
XSV's Avatar
Jeff
Old 04-12-14, 02:39 PM
tes7815
tes7815's Avatar
Where did you find the low pressure gauge? I found the high pressure one in the front next to the driver said headlight but looked for an hour for the low pressure one. Any help?
Old 06-22-14, 04:53 PM
nvd
nvd's Avatar
Default Low pressure guage location
On my 1995 ES300 the low pressure guage is located under the hood on the passenger side all the way towards the back. It has a black cap with L on it.
LEX_GS4
07-04-14 03:27 AM
mroxas
RX - 1st Gen (1999-2003)
06-09-11 02:56 AM
dee714
02-01-10 03:47 PM
patrick323
North Texas Lexus Club
09-22-09 05:41 PM
rangell
06-18-06 08:47 AM
Quick Reply: Anyone know how much A/C refrigerant the 2IS uses?
